Raspberry Pi 4 Tutorial - fatal error
19 Sep 2019 17:53 - 19 Sep 2019 17:53 #145608
Given that the lathe belonged to one attendee, the stepper drives to another, and that the Pi and Mesa cards went home with me, it is anyones guess what the final system will look like
Replied by andypugh on topic Raspberry Pi 4 Tutorial
I'm assuming that when everything's done, it's all going to be DIN rail mounted.
Last edit: 19 Sep 2019 17:53 by andypugh.
24 Nov 2019 03:53 #151092
by chopper79
Replied by chopper79 on topic Raspberry Pi 4 Tutorial
Working on getting my rpi4 up and running and have run into an issue when trying to build and install.
I followed the tutorial by JT (Thank you for the work) multiple times to see if maybe I missed something. After the 4th attempt and also using copy and paste into the terminal I still can not get it to build.
1) Verified using 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT by using "uname -a"
2) Verified successfully configured for 'uspace-Raspbian-10'-'uspace'..
3) Followed all instructions 4 times and keep ending up at the same spot.
On the rpi I do not get the deb packages only the following.
1) linuxcnc_2.8.0~pre1.dsc
2) linuxcnc_2.8.0~pre1_armhf.build
3) linuxcnc_2.8.0~pre1.tar.xz
In the terminal I get the errors shown on the picture
Any input on what I could be missing to get past this spot?
Thank you
Thank you
24 Nov 2019 11:59 #151102
Do you _need_ a deb package?
I confess that I gave up trying to make debs on Rapbian10, which is why the Pi4 SD card image that I distributed was a run-in-place build.
If you can put up with typing . ./scripts/rip-environment every time you want to start linuxcnc, or are happy to create a desktop item that calls ~/linuxcnc-dev/scripts/linuxcnc then there isn't much disadvantage to it.
The following user(s) said Thank You: chopper79
26 Nov 2019 02:06 #151274
by chopper79
I tried a few more things and then downloaded the .img file you referenced. The .img file runs good on my pi with a max of 32652 on the servo thread after 24hrs and 8 glxgears running. This also includes the occasional file open or transfer as well.
Excited to hook up my 7i76e to it and see how the machine runs.
12 Dec 2019 05:06 #152518
by RyanG
Replied by RyanG on topic Raspberry Pi 4 Tutorial
Hey guys, I have downloaded the 4.19.71-rt24-v7l+.tar.bz2, linuxcnc-doc-en_2.9.0_pre0_all.deb and the linuxcnc-uspace_2.9.0_pre0_armhf.deb from Gene's linux box on to a USB stick. How do I install this on the Pi from the stick? I noticed that John T's instruction guide has you go online and download the files from github, but I already have them. Can someone point me in the direction of installing them from the USB drive? Thank you in advance
13 Dec 2019 08:15 #152593
You can install debs with apt. But you need to give a path or apt doesn't know where to look.
so something like:
sudo apt install ./linuxcnc-uspace_2.9.0_pre0_armhf.deb
so something like:
16 Dec 2019 21:59 #152768
by AgentWD40
Replied by AgentWD40 on topic Raspberry Pi 4 Tutorial
Has anyone been using their rpi4 to actually run a machine for a while now? Is it reliable? I would really like to use it to run plasmaC but I also don't want to waste too much time on it if it's too "experimental".
The following user(s) said Thank You: grigory
17 Dec 2019 00:31 #152771
by RyanG
Got it. Thank you!
so something like:
Got it. Thank you!
24 Dec 2019 01:50 - 24 Dec 2019 05:04 #153147
by AgentWD40
I've got some additional instruction you could add to your tutorial.
On the Preempt RT Kernel, after burning the image to the SD card, and before booting into it on the pi, add a file in the ?:\Boot partition simply called wpa_supplicant.conf and another called ssh.txt. Add the following to wpa_supplicant.conf:
You can leave the ssh.txt file empty, simply having it there will cause the pi to enable ssh at boot.
I needed to do this because I've discovered I don't have the correct HDMI adapter and so can't put a monitor on my rpi yet. Obviously
you'll need a monitor to run linuxcnc anyway but at least now I can get a head start with the kernel and other setup.
howchoo.com/g/ndy1zte2yjn/how-to-set-up-...-pi-without-ethernet
{EDIT}
It might be a good idea to clarify to the audience that the following lineis kernel7"L" and not kernel7"one". Took me a few minutes to figure out where I messed that up. The fix is simply to rename the file correctly in the /boot dir.
country=US # Your 2-digit country code
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
network={
ssid="YOUR_NETWORK_NAME"
psk="YOUR_PASSWORD"
key_mgmt=WPA-PSK
{EDIT}
KERNEL=kernel7l
Last edit: 24 Dec 2019 05:04 by AgentWD40.
- Mike_Eitel
- Thank you received: 185
24 Dec 2019 08:54 #153153
by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4 Tutorial
I install very successful
xrdp
With any rdp you can use your pi without screen. I prefer this advers the vnc. My feeling is that performance is better, also starting from pi2.
Mike
xrdp
Mike
Time to create page: 0.666 seconds
