Custom Mint-19.2 with Linuxcnc
6 years 6 months ago - 6 years 6 months ago #162531 by sprintertrd
"As the buildbot builds on a debian system, there are a few issues attempting to install those packages on a Mint system as far as I've seen"
For a Debian version of Mint you could use LMDE3 or the Current beta LMDE4
They uses Cinnamon desktop though.
Last edit: 6 years 6 months ago by sprintertrd.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 6 months ago #162534 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
sprintertrd wrote: "As the buildbot builds on a debian system, there are a few issues attempting to install those packages on a Mint system as far as I've seen"
Why ?
Stretch & Buster have that covered.
Plus LMDE is a rolling edition.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 6 months ago - 6 years 6 months ago #162540 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 XFCE
[hr]
  • New 3rd April 2020 20:15
  • Add efi=runtime to kernel cmd-line for UEFI
  • When installed on UEFI only systems on first boot modify /etc/default/grub
  • Change this line from GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  • to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash efi=runtime"
  • then run
    sudo update-grub
  • Do not do this if booting and installing on BIOS or legacy boot systems
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
No longer being distributed
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 6 years 6 months ago by BeagleBrainz.
6 years 6 months ago - 6 years 6 months ago #162568 by sprintertrd
"Why ?"
No real reason other than I have heard some people don't want to use Ubuntu based distros
I no expert with Linux, It was only a suggestion.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 6 months ago #162571 by BeagleBrainz
sprintertrd wrote: "Why ?"
Well they can use the official Linuxcnc created Debian images.
To tell the truth I use Debian Stretch for my Mill. I use Mint for my Desktops & Laptops. Seems that those coming from Windows find Mint an easier experience than Debian, which is more or less correct when it comes to hardware support.
Each to their own, but I see no reason for another Debian based image with a more resource intensive desktop.
If someone was to create LMDE images, well good on them.
In reality doing 4 separate images is enough for me. Tho I would like to get involved with the build bot and have updated packages available for bionic, but I do wonder once 2.8 is made stable whether that would be necessary.
6 years 6 months ago #162580 by jbraun
Sorry but you need to talk a bit slower for this user.
The shell script is only needed if wanting to update/upgrade from the linuxcnc included on the iso? Am I understanding that correctly?
Mint with Xfce is my daily driver so I was happy to find this without having to follow a bunch of steps I don't fully understand. Easier is better.
Time to create page: 0.181 seconds
