Custom Mint-19.2 with Linuxcnc
- BeagleBrainz
- Topic Author
6 years 7 months ago - 6 years 7 months ago #160955
by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Ok Intel seems to have decreed the removal of Legacy boot from Gemini Lake Platforms.
I just tried booting my T530 Thinkpad with that image, I usually use VBox to check images, and have the T530 set to boot in legacy mode. I had the same issues. I think it may be a kernel issue related to video in UEFI mode. Or maybe a grub thing, as I had an issue previously......it's mentioned somewhere earlier in the thread, and delayed the release of a RTAI iso. So the boot issue is confirmed, sorry about the issue and for not thoroughly checking and also thanks for the feed back and bringing it up.
I'm going to boot a RT_PREEMPT image and report back. In the meantime when you get the grub screen press e to edit the entry and add nomodeset to the kernel command line and if quiet & splash are there remove them. I'm not sure if this will work but lets rule it out anyway.
UPDATE:
Ok booted a RT_PREEMPT version with the T530 set to UEFI only mode, and am typing this from a Live Session. There is a new RTAI kernel mentioned on the forum. I'll have a look at the config and see if intel GPU driers are enabled in the kernel (which I'm thinking maybe the issue). Towards the end of the day I'll experiment and see what I can come up with.
But for the time being, my Beagle, known as The Butter Dog, needs time at the park.....and the Beagle must be obeyed.
UPDATE:
Last edit: 6 years 7 months ago by BeagleBrainz.
- BeagleBrainz
- Topic Author
6 years 7 months ago #160973
by BeagleBrainz
OK T530 set to UEFI only boot
Rebuilt RTAI 4.14.173 with Intel GPU drivers
Booted to desktop fine and now typing this from a live session.
Need to rebuild rtai modules & rebuild linuxcnc to suit the new kernel.
Once I'm happy with all that I'll throw up an ISO on da goolge drive.
So far so good.
The Big Question is what latency numbers will we get.
So far so good.
6 years 7 months ago #160985
by cncbeagle
Replied by cncbeagle on topic Custom Mint-19.2 with Linuxcnc
Nomodeset did not help. I have to admit adding that parameter at boot is testing my Linux knowledge a bit. I vaguely remember having to do that in the distant past but it looked very different then!
Our Beagles Brewster and Blush say Hi to The Butter Dog. They're taking a break from chasing squirrels out of our yard.
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Topic Author
6 years 7 months ago #161050
by BeagleBrainz
OK booting is successful via UEFI now, at least on my Test machine.
Issues have arisen forum.linuxcnc.org/9-installing-linuxcnc...ges?start=140#161047
Hopefully it's some dumb mistake on my part or particular to my machine and easily fixed.
Butters replies AAAARRRRRROOOOOOOOOOOOOOOOOOO!!!
- BeagleBrainz
- Topic Author
6 years 7 months ago #161067
by BeagleBrainz
Bad news mate, whilst I managed to produce a RTAI UEFI bootable image only one core is initialised when booting UEFI. Legacy booting, which is no good for you and your board, will initialise all cores.
So this is where we are now.......tho it does appear strange.
6 years 7 months ago #161068
by phillc54
Replied by phillc54 on topic Custom Mint-19.2 with Linuxcnc
Doesn't LinuxCNC on RTAI run best on only one core?Bad news mate, whilst I managed to produce a RTAI UEFI bootable image only one core is initialised when booting UEFI.
Time to create page: 0.306 seconds
