Custom Mint-19.2 with Linuxcnc
6 years 7 months ago #159059 by phillc54
BeagleBrainz wrote: gparted is removed as part of the Mint install process along with the ubiquity stuff and some bits and pieces.
Fair enough, It is just me being lazy...
linuxcnc 2.8 builds ok
linuxcnc 2.9 has issues /src/emc/rs274ngc/interp_g7x.cc ( I don't know if this issue has been sorted yet)
It looks like it has, it just built perfectly. I did a complete build with all documentation.
This may be fixed by installing gcc-8 and checking the instructions to make gcc-8 the default. As gcc-8 is the default in buster.
askubuntu.com/questions/1028601/install-...only-on-ubuntu-18-04
I started a clean build of kernel packages using the gcc-8 compiler. I needed to do more messing around with the control file fro gcc-7, which I couldn't be bothered with ATM. Tho I may have to do some modding.
But maybe it maybe worth waiting to till the next release of Mint.
Yep, probably better off waiting.
The thing I find odd is that Mint 19.2 is supposedly based on buster/sid and they don't even list any rt linux images in the 42 thousand imges they do list.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago #159234 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
New Kernel Packages
Version 20200305 includes all these updated packages
Kernel 4.19.106-rt44-lcnc-1 to update installs from 20200301 & earlier.
linux-image drive.google.com/open?id=1MTigCV53dDRaw67dVQ47R7wGieU1WXkH
linux-headers drive.google.com/open?id=1PEk3M6Lr-iHqWOmyixmefdUSCe6kqN1Z
linux-libc-dev drive.google.com/open?id=1jxCxAxkv-yoEOK-M4qNeUk642szgDX84
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 7 months ago #159235 by BeagleBrainz
New Linuxcnc-uspace Packages
Linuxcnc-uspace_2.8.0~pre1.5482.g7302cc1ba_amd64 to update installs for 20200301 & earlier
linuxcnc-uspace drive.google.com/open?id=13BgAMU8mfQunrJqE466h4A67kMmOXWII
linuxcnc-uspace-dev drive.google.com/open?id=1ULs12SgBVZY0fEX2gPqODP1od6OW7yFP
linuxcnc-doc-en drive.google.com/open?id=1dB_vjXEIndOHPWfWx6almoFSpEHnC1bn
linuxcnc-doc-es drive.google.com/open?id=1mp7y-ozlrmTz2KCxy66y5sWnjDZFHuKY
linuxcnc-doc-fr drive.google.com/open?id=15AKgjbdMi6rROCIl5BKDFuwv_D3jaqx6
Last edit: 6 years 7 months ago by BeagleBrainz.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 6 months ago #159240 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
[hr]
  • New 5rd March 2020 21:48
  • Kernel Upgraded to Linux 4.19.106-rt44
  • /etc/linuxmint/respin-version.txt contains info regarding release eg kernel version, linuxcnc version to easily help ID the ISO
  • Gparted is not removed during install
  • HTML Documentation sorted
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 6 years 6 months ago by BeagleBrainz. Reason: No longer available do not ask for access
6 years 7 months ago #159284 by andypugh
BeagleBrainz wrote: Having no joy with RTAI kernel, graphics are really sluggish on my T530, glxgears barley runs.
Maybe some hints here?
sourceforge.net/p/emc/mailman/emc-develo...hoo.com/#msg36879222
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 7 months ago #159289 by BeagleBrainz
I sorted it out, having grub boot menu be a text menu only.
It was confusing as it only came up as an issue after being installed on the T530, didn't manifest it self when installed on my Lenovo M90P desktop, running the live cd on the T530 and running as a virtual machine on the T530 did not produce this problem.
Apart from the screen resolution only being 1024x768 the Desktop is smooth and without the feeling of moving through molasses .
Fix is here, simple but took a while to diagnose.
forum.linuxcnc.org/9-installing-linuxcnc...xcnc?start=10#157661
On another Andy you maybe able to help with this one.
I've been working with a commit that sorted an issue with pncconf and another issue that escapes me, thanks to Chris for his quick replies.
Anyways I made some modifications to the debian package build so that the html docs are produced as a separate package. How does one go about merging those changes with 2.8 locally ?
I haven't made any changes to turn this on or off when doing a
debian/configure uspace noauto
Many Thanks
Rob
Time to create page: 0.081 seconds
