Custom Mint-19.2 with Linuxcnc
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 7 months ago #159296 by BeagleBrainz
Last edit: 6 years 7 months ago by BeagleBrainz.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 6 months ago #159301 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Welcome to a respin of Linux Mint 19.2 MATE
[hr]
  • New 6th March 2020 14:04
  • Linuxcnc version linuxcnc_2.8.0~pre1~rmurphy.htmldocs~1c3c94442
  • 2.8 merged into local sources 6th March 2020
  • HTML docs are now a separate package
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 6 years 6 months ago by BeagleBrainz. Reason: No longer available do not ask for access
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 7 months ago #159323 by BeagleBrainz
RTAI 4.14.148-rtai packages for testing
  • Latest 2.8
  • Produces HTML docs as a separate package
Link to folder:
drive.google.com/open?id=1A0ZqUSJqYkwB9zZBrRxkhNyxE3CMmz-g
Download install-linuxcnc-pkg.sh, qtvcp.sh and linuxcnc linuxcnc-dev linuxcnc-doc-en linuxcnc-doc-html deb files
The matching kernel files have been included in the folder, not needed for installs using the RTAI ISOs in this thread.
The kernel packages are only for those that know 100% what they doing and are not running that particular kernel.
Uninstall existing linuxcnc packages
sudo apt-get remove linuxcnc linuxcnc-dev linuxcnc-doc-en
cd to the directory where all the files are.
Install the Linuxcnc packages, this script is tied to this version: installs linuxcnc linuxcnc-dev linuxcnc-doc-en linuxcnc-doc-html
sh install-linuxcnc-pkg.sh
To fix up and existing setup with qtvcp or to install qtvcp. If you haven't got qtvcp insatlled or don't want to install qtvcp do not run the next command:
sudo sh qtvcp.sh
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 6 months ago #159389 by BeagleBrainz
[hr]
  • New 7th March 2020 14:04
  • Base image is from the 20200306 RT image
  • Linuxcnc RTAI version linuxcnc_2.8.0~pre1~rmurphy.htmldocs~1c3c94442
  • Linux Kerenl 4.14.148-rtai-amd64
  • If screen doesn't show login prompt move the mouse in circles for a few seconds
  • Login screen issue is an entropy issue that shows up with fast fast machines and/or SSDs
  • /etc/linuxmint/respin-version.txt contains info regarding release
  • Gparted is not removed during install
  • Updated packages at above creation
  • pncconf will work with firmware in /lib/firmware/hm2
  • New desktop shortcut to Linuxcnc Forums
  • New desktop shortcut to first page of Linuxcnc forum thread for this iso
  • New desktop shortcut to Linuxcnc github
  • Renamed this file to respin-20200301.txt & moved to /etc/linuxmint
  • New desktop shortcut to open this file with geany
  • Removed CNC Menu item pointing to html docs & html docs removed
  • update lsb Description: Linuxcnc Powered by Linux Mint 19.2 Tina
  • ISO is now UEFI bootable
  • Moved this file to $HOME/Desktop
  • QTVCP is now included
  • Glade3.8.6 has been included
  • HTML Docs have been included and added to CNC Menu
  • $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
  • Running this script by
    sh ~/utils/bin/get_linuxcnc_build_deps.sh
  • will download and install the dependencies to build linuxcnc form source
  • JT's excellent tutorial can be found here to get sources from git and compiling
  • www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
Iso Image:
MD5Sum:
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 7 months ago - 6 years 6 months ago #159518 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 XFCE
[hr]
  • New 8th March 2020 14:04
  • This post covers both RTAI & RT_PEEMPT versions of XFCE
  • Mint version reverted from 19.3 to 19.2 to keep inline with MATE respins
  • See previous MATE announcements for details
Iso Image:
MD5Sum:
6 years 7 months ago - 6 years 7 months ago #159999 by billykid
hi I tried the iso preempt-rt version and it works normally with latency of about 32000 + 32000. only problem is the slow start. more than a minute. with the standard kernel you don't wait about 20 seconds.
these are the data of the pc
mauro
Last edit: 6 years 7 months ago by billykid.
The following user(s) said Thank You: BeagleBrainz
Time to create page: 0.126 seconds
