Welcome to a respin of Linux Mint 19.2 MATE
[hr]
- New 1st March 2020 21:48]
- Updated packages at above creation
- Linuxcnc Version linuxcnc_2.8.0~pre1.5482.g7302cc1ba_amd64
- pncconf will work with firmware in /lib/firmware/hm2
- New desktop shortcut to Linuxcnc Forums
- New desktop shortcut to first page of Linuxcnc forum thread for this iso
- New desktop shortcut to Linuxcnc github
- New desktop shortcut to install deps for building Linuxcnc, click and run once
- Renamed this file to respin-20200301.txt & moved to /etc/linuxmint
- New desktop shortcut to open this file with geany
- Removed CNC Menu item pointing to html docs & html docs removed
- update lsb Description: Linuxcnc Powered by Linux Mint 19.2 Tina
- New 27 February 2020 11:14
- ISO is now UEFI bootable
- Moved this file to $HOME/Desktop
- New 22 February 2020 22:04
- QTVCP is now included
- Glade3.8.6 has been included
- HTML Docs have been included and added to CNC Menu
- $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
- Running this script by
sh ~/utils/bin/get_linuxcnc_build_deps.sh
- will download and install the dependencies to build linuxcnc form source
- JT's excellent tutorial can be found here to get sources from git and compiling
www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
- Original Release
- Linux Mint 19.2 with RT_PREEMPT
- Linuxcnc v2.8 from sources dated 15 Feb 2020
- Geany, gFTP & Midnight commander included
- Gimp isn't the default program to open pdfs
- Initramfs modified to work when booted from a vfat filesystem, ie supports Multiboot
- No support for qtvcp but can be added later
- Mesaflash and limited hostmot2 firmware included
- If booting stalls on Regenerating SSL certifcates please press shift, on a VM make sure the keyboard is captured
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update
sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
