Clive S wrote:
Re:
login with your username & password
sudo chown -R cnccontroller /home/cnccontroller
sudo reboot
This error-ed for me should cnccontroller be the user name ie in my case usr and psw is cnc
I assumed, from your screenshot, that cnccontroller was your user name.
BeagleBrainz wrote: Yep, if you downloaded the latest release open up the read me on the desktop and that has instructions on how to install the dependencies, please report if anything is missing from the list, then pull the sources from linuxcnc github checkout the branch you want and go for it. A rip install would probably be the best option so to keep the original install all good.
bensttech wrote: can you post a copy of the deps list? the build i dl has readme but doesn't mention SRC release building.
Here's the list I use: forum.linuxcnc.org/9-installing-linuxcnc...xcnc?start=50#157948
Do you have adirectory ?Code:$HOME/utils/bin
If you do the file you want should be in there.
Did you download this version forum.linuxcnc.org/9-installing-linuxcnc...xcnc?start=60#158193 or a previous one or MATE RTAI or any of the XFCE ones ?
