Custom Mint-19.2 with Linuxcnc
21 Feb 2020 02:15 #158081 by rodw
Replied by rodw on topic Custom Mint-19.2 with Linuxcnc
You can get another 100 Gb of storage for $2 a month or so. I think its paid via Google Play.
I've had a Gsuite account for over 10 years now and that is cheap as chips for 30 Gb. I think its about $5 a month per user. I could upgrade to a pro plan which gives unlimited storage but its about $15 a month per user. That gives you a proper group drive and lots more features which would be handy.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
21 Feb 2020 03:08 #158083 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Google One is about 25 or so beer tokens a year and gives you about 100GB, something to think about.
21 Feb 2020 10:27 #158105 by Clive S
Replied by Clive S on topic Custom Mint-19.2 with Linuxcnc
If Clive is watching, if you are still having problems with your BRIX J1900, maybe give this one a go.
Rod. I used it as a Win10 box instead. The blurb that came with it said in was a win only box. I think it is a version thing as I know there are several people that have used them successfully . I have also seen adverts for them stating suitable Win or Linux. The company that I found actually said good with Linux Mint.
Sorry late with this but my central heating boiler failed and that took priority with me fitting a new boiler.
21 Feb 2020 11:24 #158115 by rodw
I wondered what you did with it.
Boiler!!! Central Heating!!!! it was 33.1 degrees C here today! It was almost cool!
21 Feb 2020 12:01 #158125 by tommylight
Replied by tommylight on topic Custom Mint-19.2 with Linuxcnc
5 degrees C here in the morning, it's been a springy winter here, mostly sunny with temps up to 15 ! some days ago i was cleaning the workshop in my t-shirt and that is very nice, but that will cause us some trouble during summer regarding water.
  • BeagleBrainz
  • Visitor
  • Visitor
21 Feb 2020 16:49 #158150 by BeagleBrainz
We went from major bush fires to major storm damage in a week here. Gotta love Australia summers, half the country is on fire and the other half is under water.
In related news even the eucalypts have been declared a dangerous menace that exist to kill. Now that Greta tells us the air around Is killing the least dangerous thing over here are the humans.
21 Feb 2020 18:04 - 21 Feb 2020 18:05 #158151 by tommylight
LOL
You've got to love Australia ! Never boring !
Last edit: 21 Feb 2020 18:05 by tommylight.
  • BeagleBrainz
  • Visitor
  • Visitor
21 Feb 2020 23:01 - 02 Apr 2020 23:16 #158162 by BeagleBrainz
Glade-3 available for Mint 19.2 & 19.3 for those that want or require it.
Link:
No longer available do not ask for access
Howto install:
Open folder containing file in terminal
sudo apt-get install ./glade3_3.8.6-1_amd64.deb
Shortcut should appear under "Programming". If shortcut does not appear log out and log back in.
If using GDebi ignore "Glade3 UI BUilder for use with Linuxcnc Built for Linux Mint 18.3" as it is fine for Mint 19.
Last edit: 02 Apr 2020 23:16 by BeagleBrainz. Reason: No longer available do not ask for access
  • BeagleBrainz
  • Visitor
  • Visitor
22 Feb 2020 11:31 - 02 Apr 2020 23:15 #158193 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
  • Linux Mint 19.2 with RT_PREEMPT
  • Linuxcnc v2.8 from sources dated 15 Feb 2020
  • Geany, gFTP & Midnight commander included
  • Gimp isn't the default program to open pdfs
  • Initramfs modified to work when booted from a vfat filesystem, ie supports Multiboot
  • No support for qtvcp but can be added later
  • Mesaflash and limited hostmot2 firmware included
  • If booting stalls on Regenerating SSL certifcates please press shift, on a VM make sure the keyboard is captured
  • New 22 February 2020 22:04
  • QTVCP is now included
  • Glade3.8.6 has been included
  • HTML Docs have been included and added to CNC Menu
  • $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
  • Running this script by
    sh ~/utils/bin/get_linuxcnc_build_deps.sh
  • will download and install the dependencies to build linuxcnc form source
  • JT's excellent tutorial can be found here to get sources from git and compiling
  • www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
  • Note source code repositories are already included.
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update
sudo apt-get dist-upgrade
Iso Image:
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 02 Apr 2020 23:15 by BeagleBrainz. Reason: No longer available do not ask for access
22 Feb 2020 11:47 #158194 by Clive S
Is the link missing for the download, or have you redone the previous one? Thanks
Time to create page: 0.310 seconds
