Custom Mint-19.2 with Linuxcnc
- BeagleBrainz
- Visitor
22 Feb 2020 11:53 - 22 Feb 2020 13:47 #158195
by BeagleBrainz
TBA = To Be Announced
I'll edit the post once everything is up.
It's taking a bit of time to clear up space on my google drive.
Files uploaded and links added.
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Last edit: 22 Feb 2020 13:47 by BeagleBrainz.
- tivoi
- Thank you received: 20
26 Feb 2020 14:22 #158542
by tivoi
hi, thanks your share
i have prolem with hal joint.N.joint−vel−cmd
Replied by tivoi on topic Custom Mint-19.2 with Linuxcnc
Welcome to a respin of Linux Mint 19.2 MATE
- Linux Mint 19.2 with RT_PREEMPT
- Linuxcnc v2.8 from sources dated 15 Feb 2020
- Geany, gFTP & Midnight commander included
- Gimp isn't the default program to open pdfs
- Initramfs modified to work when booted from a vfat filesystem, ie supports Multiboot
- No support for qtvcp but can be added later
- Mesaflash and limited hostmot2 firmware included
- If booting stalls on Regenerating SSL certifcates please press shift, on a VM make sure the keyboard is captured
- New 22 February 2020 22:04
- QTVCP is now included
- Glade3.8.6 has been included
- HTML Docs have been included and added to CNC Menu
- $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
- Running this script by
sh ~/utils/bin/get_linuxcnc_build_deps.sh- will download and install the dependencies to build linuxcnc form source
- JT's excellent tutorial can be found here to get sources from git and compiling
- www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
- Note source code repositories are already included.
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
drive.google.com/open?id=1Cnv-u9o0Bwaugv5KVAoTP1XnWXLjKSuC
MD5Sum:
drive.google.com/open?id=1xbTSFGVbLiDtPu1krFRUIpgKoVS9bksH
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
- porshe
26 Feb 2020 16:05 #158552
by porshe
Replied by porshe on topic Custom Mint-19.2 with Linuxcnc
Can you help me? I'm trying to install on Mint-19.2-rtai linuxcnc-2.9 writes an error.
Warning: Spoiler!
Compiling emc/task/taskmodule.cc
In file included from emc/rs274ngc/interp_array_types.hh:21:0,
from emc/task/taskmodule.cc:42:
emc/rs274ngc/paramclass.hh:24:0: warning: "BOOST_PYTHON_MAX_ARITY" redefined [enabled by default]
#define BOOST_PYTHON_MAX_ARITY 4
emc/task/taskmodule.cc:21:0: note: this is the location of the previous definition
#define BOOST_PYTHON_MAX_ARITY 7
g++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.8/README.Bugs> for instructions.
make: *** [objects/emc/task/taskmodule.o] Error 4
operator@tormachpcnc:~/linuxcnc-dev/src$
- BeagleBrainz
- Visitor
26 Feb 2020 17:08 #158558
by BeagleBrainz
As this would seem to be an issue with your config, it would be more appropriate to start a new thread with a better description of your issue and include your Hal and ini files.
- BeagleBrainz
- Visitor
26 Feb 2020 17:17 #158559
by BeagleBrainz
What is it you are actually trying to do. The images in this thread have linuxcnc installed and are basically install create a config and run your machine.
A somewhat more detailed description of your installation and what dependencies you installed is needed.
Warning: Spoiler!Compiling emc/task/taskmodule.cc
- porshe
26 Feb 2020 17:40 #158560
by porshe
I am trying to install on Linux Mint with RTAI from this thread forum.linuxcnc.org/9-installing-linuxcnc...iso-with-rtai-and-rt linuxcnc from here https: // github. com / LinuxCNC / linuxcnc.When happens ./configure I get errors that are under the spoiler.
- BeagleBrainz
- Visitor
26 Feb 2020 18:10 #158561
by BeagleBrainz
The thread you linked to is a different thread to this.
The linked thread is by tommy and not myself.
The image you are using are not the ones I created.
If you start reading this thread from the beginning you will find a link to my version of Mint with an RTAI kernel and matching linuxcnc pre installed. There is no need to build linuxcnc on the images I have supplied for normal use.
The images that myself and tommy have supplied are completely different.
- porshe
26 Feb 2020 18:36 #158562
by porshe
Thanks for the answer. I'll try your image.
- BeagleBrainz
- Visitor
26 Feb 2020 18:48 #158564
by BeagleBrainz
No probs, after reading tommy’s whole thread it does look a little confusing.
There is actually 2 rtai versions one with MATE desktop and one with XFCE desktop. Apart from the desktops they are pretty much the same.
Any issues just give a yell on this thread.
- Thank you received: 7488
26 Feb 2020 18:56 - 27 Feb 2020 18:53 #158565
Replied by tommylight on topic Custom Mint-19.2 with Linuxcnc
Hmmm why are you trying to compile Linuxcnc on an install with Linuxcnc included ???
That RTAI version also has dev installed.
Last edit: 27 Feb 2020 18:53 by tommylight. Reason: typos
Time to create page: 0.284 seconds
