Custom Mint-19.2 with Linuxcnc
6 years 8 months ago - 6 years 8 months ago #158151 by tommylight
Last edit: 6 years 8 months ago by tommylight.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago - 6 years 6 months ago #158162 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Glade-3 available for Mint 19.2 & 19.3 for those that want or require it.
Link:
No longer available do not ask for access
Howto install:
Open folder containing file in terminal
sudo apt-get install ./glade3_3.8.6-1_amd64.deb
Shortcut should appear under "Programming". If shortcut does not appear log out and log back in.
If using GDebi ignore "Glade3 UI BUilder for use with Linuxcnc Built for Linux Mint 18.3" as it is fine for Mint 19.
Last edit: 6 years 6 months ago by BeagleBrainz. Reason: No longer available do not ask for access
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago - 6 years 6 months ago #158193 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
[hr]
  • Linux Mint 19.2 with RT_PREEMPT
  • Linuxcnc v2.8 from sources dated 15 Feb 2020
  • Geany, gFTP & Midnight commander included
  • Gimp isn't the default program to open pdfs
  • Initramfs modified to work when booted from a vfat filesystem, ie supports Multiboot
  • No support for qtvcp but can be added later
  • Mesaflash and limited hostmot2 firmware included
  • If booting stalls on Regenerating SSL certifcates please press shift, on a VM make sure the keyboard is captured
  • New 22 February 2020 22:04
  • QTVCP is now included
  • Glade3.8.6 has been included
  • HTML Docs have been included and added to CNC Menu
  • $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
  • Running this script by
    sh ~/utils/bin/get_linuxcnc_build_deps.sh
  • will download and install the dependencies to build linuxcnc form source
  • JT's excellent tutorial can be found here to get sources from git and compiling
  • www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
  • Note source code repositories are already included.
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
6 years 8 months ago #158194 by Clive S
Is the link missing for the download, or have you redone the previous one? Thanks
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #158195 by BeagleBrainz
[strike]TBA = To Be Announced
I'll edit the post once everything is up.[/strike]
It's taking a bit of time to clear up space on my google drive.
Files uploaded and links added.
Last edit: 6 years 8 months ago by BeagleBrainz.
6 years 8 months ago #158542 by tivoi
BeagleBrainz wrote: Welcome to a respin of Linux Mint 19.2 MATE
[hr]
Iso Image:
drive.google.com/open?id=1Cnv-u9o0Bwaugv5KVAoTP1XnWXLjKSuC
MD5Sum:
drive.google.com/open?id=1xbTSFGVbLiDtPu1krFRUIpgKoVS9bksH
hi, thanks your share
i have prolem with hal joint.N.joint−vel−cmd
Time to create page: 0.532 seconds
