Custom Mint-19.2 with Linuxcnc
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #157802 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
I'm 4G only and really happy with it. Makes more sense when you are renting.
I think it only took delivery time to get online via 4G not the 10 million weeks for NBN.
6 years 8 months ago #157803 by phillc54
It must have slowed down recently, mine took only 9 million weeks.
6 years 8 months ago #157820 by tommylight
The following user(s) said Thank You: BeagleBrainz
6 years 8 months ago #157837 by Clive S
BeagleBrainz wrote: For some reason it may appear that your home directory ended up being owned by root.
Clive could you try doing the same thing in the same order on a Std Mint install image. It maybe a bug in the Mint installer.
I deleted and re downloaded the linuxmint-19.2.0-2020.02.18-rtai-lcnc-v28-mate-64bit ).iso agian with the same result. It booted to the live no prob. then installed to HD and it went to the message "install complete restart now" a short while later the message came up with "remove medium then press enter" then I saw the spector V2 kernel not compile bit come up. That was it black screen
I have also downloaded the linuxmint-19.3.0-2020.02.19-rtai-lcnc-v28-xfce-64bit.iso This worked fine including installed to HD.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #157838 by BeagleBrainz
The "spector V2 kernel" message is particular to the RTAI kernel, it will come up on both the Mate & XFCE iso's. This can be confirmed via running
sudo dmesg | grep Spectre
Output should similar to this
Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Spectre V2 : Spectre mitigation: kernel not compiled with retpoline; no mitigation available!
One thing I have noticed on my laptop is that with the RTAI mate install I have to press a key and wiggle the mouse before the login comes up. I checked the dmesg output and it looks like it may be related to entropy.
Last edit: 6 years 8 months ago by BeagleBrainz.
6 years 8 months ago #157841 by Clive S
BeagleBrainz wrote: The "spector V2 kernel" is particular to the RTAI kernel, it will come up on both the Mate & XFCE iso's.
One thing I have noticed on my laptop is that with the RTAI mate install I have to press a key before the login comes up. Not too sure what this issue is but I have a feeling it maybe related to the Nvidia GPU I have in the laptop. I can't see I've seen this issue on my desktop.
It never got tos see the login screen but I might have clicked the auto login when it was asking the the user name etc on install.
Never mind I tried. All the other iso's you produced have worked fine. Thanks for all the hard work you put in.
Time to create page: 0.386 seconds
