Custom Mint-19.2 with Linuxcnc
6 years 8 months ago #157753 by cncthunder
Installed the new RTAI on an old Mini-itx GA-E350n.
Did the update commands and all seems to work. Latency is under 10000!!
The test build from the beginning of this thread with Preemt RT was 10 times worse 100k.
Looks great so far. Many thanks
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #157756 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
Thanks for the feedback.
This iso took a few goes as I kept having brain farts and forgetting little things.
6 years 8 months ago #157769 by Clive S
What happens after before the ICEAuthority message and what happens after ?
This message was a popup screen with a close button. but it would not close so had to power off.
I will re download and try again in the morning.
The only thing I did different from the other ISO's I tested is that when the usb booted to live. I went into admin and power saving then changed it so it would not go to sleep. ie. changed 30min to never I also did the same with the screen saver.
6 years 8 months ago #157771 by tommylight
Clive S wrote: The only thing I did different from the other ISO's I tested is that when the usb booted to live. I went into admin and power saving then changed it so it would not go to sleep. ie. changed 30min to never I also did the same with the screen saver.
That should have no effect on installation at all. In a bit maybe, just maybe i can grab one of my laptops and test the installation.
6 years 8 months ago #157773 by Clive S
Yes I agree Tom but I was just trying to say exactly what I did different. The live install went fine and the install to hard drive seemed to go fine until the end.
But I don't mind trying again
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #157778 by BeagleBrainz
For some reason it may appear that your home directory ended up being owned by root.
Clive could you try doing the same thing in the same order on a Std Mint install image. It maybe a bug in the Mint installer.
Time to create page: 0.446 seconds
