Custom Mint-19.2 with Linuxcnc
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #158564 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
No probs, after reading tommy’s whole thread it does look a little confusing.
There is actually 2 rtai versions one with MATE desktop and one with XFCE desktop. Apart from the desktops they are pretty much the same.
Any issues just give a yell on this thread.
6 years 8 months ago - 6 years 8 months ago #158565 by tommylight
Hmmm why are you trying to compile Linuxcnc on an install with Linuxcnc included ???
That RTAI version also has dev installed.
Last edit: 6 years 8 months ago by tommylight. Reason: typos
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #158566 by BeagleBrainz
I think he got a little confused, it can happen at times.
On another note I have created a new image of Mint & RT that should boot from UEFI without having to change to a so called "Legacy mode". tested on VBox with UEFI enabled in a virtual machine.
Silly me was unaware that Cubic required the installation of syslinux & isolinux to create UEFI images.
Also have moved the readme to the desktop so hopefully it may get read more often. Just waiting from reply from another member about a message regarding "mismatched versions of a particular component". In this thread: forum.linuxcnc.org/9-installing-linuxcnc...ion-usb-not-bootable
No info has been given as where the message appears.
One thing to note is that when the image is created with UEFI support the image can be mounted from within caja, the non UEFI images wont mount unless manually loop mounted.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago - 6 years 6 months ago #158595 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
[hr]
  • New 27 February 2020 11:14
  • ISO is now UEFI bootable
  • Moved this file to $HOME/Desktop
  • New 22 February 2020 22:04
  • QTVCP is now included
  • Glade3.8.6 has been included
  • HTML Docs have been included and added to CNC Menu
  • $HOME/utils/bin/get_linuxcnc_build_deps.sh has been included
  • Running this script by
    sh ~/utils/bin/get_linuxcnc_build_deps.sh
  • will download and install the dependencies to build linuxcnc form source
  • JT's excellent tutorial can be found here to get sources from git and compiling
  • www.gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
  • Original Release
  • Linux Mint 19.2 with RT_PREEMPT
  • Linuxcnc v2.8 from sources dated 15 Feb 2020
  • Geany, gFTP & Midnight commander included
  • Gimp isn't the default program to open pdfs
  • Initramfs modified to work when booted from a vfat filesystem, ie supports Multiboot
  • No support for qtvcp but can be added later
  • Mesaflash and limited hostmot2 firmware included
  • If booting stalls on Regenerating SSL certifcates please press shift, on a VM make sure the keyboard is captured
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
Unlike other images I posted this has been created using a virgin install of Mint 19.2 on real hardware.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 6 years 6 months ago by BeagleBrainz. Reason: No longer available do not ask for access
6 years 8 months ago #158607 by tivoi
i was check , there are errors in the instructions of linuxcnc 2.8 "motion"
joint.N.joint−vel−cmd
rite is joint.N.vel−cmd
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html
6 years 8 months ago #158609 by emilvv
Hello,
Is it possible to 'produce' ISO file with RTAI for LPT ?
Thank you,
Emil
Time to create page: 0.423 seconds
