Custom Mint-19.2 with Linuxcnc
6 years 8 months ago #158552 by porshe
Can you help me? I'm trying to install on Mint-19.2-rtai linuxcnc-2.9 writes an error.
Warning: Spoiler!
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #158558 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
As this would seem to be an issue with your config, it would be more appropriate to start a new thread with a better description of your issue and include your Hal and ini files.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #158559 by BeagleBrainz
porshe wrote: Can you help me? I'm trying to install on Mint-19.2-rtai linuxcnc-2.9 writes an error.
Warning: Spoiler!
What is it you are actually trying to do. The images in this thread have linuxcnc installed and are basically install create a config and run your machine.
A somewhat more detailed description of your installation and what dependencies you installed is needed.
6 years 8 months ago #158560 by porshe
I am trying to install on Linux Mint with RTAI from this thread forum.linuxcnc.org/9-installing-linuxcnc...iso-with-rtai-and-rt linuxcnc from here https: // github. com / LinuxCNC / linuxcnc.When happens ./configure I get errors that are under the spoiler.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 8 months ago #158561 by BeagleBrainz
The thread you linked to is a different thread to this.
The linked thread is by tommy and not myself.
The image you are using are not the ones I created.
If you start reading this thread from the beginning you will find a link to my version of Mint with an RTAI kernel and matching linuxcnc pre installed. There is no need to build linuxcnc on the images I have supplied for normal use.
The images that myself and tommy have supplied are completely different.
6 years 8 months ago #158562 by porshe
Thanks for the answer. I'll try your image.
Time to create page: 0.280 seconds
