Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
15 Mar 2020 10:04 - 15 Mar 2020 11:03 #160273 by BeagleBrainz
This is for a Mint installation that does not already have a RT_PREEMPT kernel nor Linuxcnc installed.
ie a Virgin installation of Linux Mint 19.x
All kernel packages & linuxcnc packages are downloaded automatically from my google drive.
Download the attached file, open a terminal and in the directory you downloaded to run by
mv install-uspace.sh.txt install-uspace.sh
chmod +x install-uspace.sh
sudo ./install-uspace.sh
Then follow the prompts and off you go. Tested on Mint 19.2 XCFE, MATE should not be an issue.
Last edit: 15 Mar 2020 11:03 by BeagleBrainz.
  • Moderator
  • Moderator
15 Mar 2020 10:57 #160276 by tommylight
sudo ./insta-uspace.sh
:S
Missing 2 L !
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 11:04 - 15 Mar 2020 11:04 #160277 by BeagleBrainz
My excuse is The Toilet Paper Crisis sweeping Australia has affected me :P
Last edit: 15 Mar 2020 11:04 by BeagleBrainz.
15 Mar 2020 11:13 - 15 Mar 2020 11:18 #160279 by bevins
Yeah great. Just finishing the third linuxcnc on linux mint this weekend. Now you post this.
Compiling preempt rt kernel.
Last edit: 15 Mar 2020 11:18 by bevins.
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 11:33 #160284 by BeagleBrainz
Oh you missed the the Mint respin with Linuxcnc already setup and ready for installation ?
forum.linuxcnc.org/9-installing-linuxcnc...with-linuxcnc#157411
  • Moderator
  • Moderator
15 Mar 2020 11:38 #160286 by tommylight
And you missed this
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
But wait, i recall someone...........never mind ! :)
The following user(s) said Thank You: bevins
15 Mar 2020 12:37 #160289 by bevins
Yeah I missed that. All that.
I got this down pat with JT's gnipsel page and note I have. It works everytime now, but it is long.
We need a webpage with this. not in the forum unless they sticky it.
  • Moderator
  • Moderator
15 Mar 2020 12:39 #160291 by tommylight
They are both sticky, under the installation section.
15 Mar 2020 12:44 #160292 by bevins
Yeah, I missed all that. ok no loss. I am going to dig up another hard drive and create one of these dvd's and test it out and see how long it takes.
thanks......
15 Mar 2020 12:48 #160293 by bevins
Looks like I will have a chance to try it out....
