Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
  • Moderator
  • Moderator
15 Mar 2020 12:51 #160295 by tommylight
It takes about 20 to 40 minutes, and that is being generous !
From a USB drive, i have not used DVD in quite a while.
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
15 Mar 2020 12:52 #160296 by BeagleBrainz
The ones remastered with linuxcnc take no longer than doing a install of Mint.
From an install point of view there’s no difference.
The script can take a while as it will install the kernel and linuxcnc then optionally install the deps for qtvcp and the deps to rebuild linuxcnc.
The only thing not on the DVD is the deps to rebuild linuxcnc but there is a desktop shortcut that will do that.
15 Mar 2020 12:54 #160298 by bevins
I havent had much luck with usb drives. Maybe I will try if I can find one.
What size would a 2 gig usb drive work?
  • Moderator
  • Moderator
15 Mar 2020 12:57 #160299 by tommylight
Nope, Linux Mint only, 2.1GB, most of the ready versions are from 2.4 to 2.6 GB.
Or Linux Mint 19.3 with XFCE, 2.0 GB, but if you are used to Mate, stick to it.
15 Mar 2020 13:04 #160301 by bevins
ok, I'll go find a bigger usb or dvd.
15 Mar 2020 14:50 #160311 by bevins
I dont know what it is with me and mint 19. Can never get it to work. I downloaded the
image linuxmint-19.2.0-LCNC-2.8-RT-20200305-UEFI-mate-64bit.iso
and it booted in command prompt.
Had some errors trying to start some daemons.
15 Mar 2020 14:51 #160312 by bevins
AH, I got cursor now. It is a very slow boot.
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 17:49 #160321 by BeagleBrainz
Maybe one has gremlins ?
Can’t say what the issue is, I’ve tested it on a couple of laptops from i5 to Core 2 duo, a desktop with an i5 the only thing that was an issue was the dumpster find core 2 duo iMac, but that an Apple thing. But I did eventually get it Mint going on it, which was the reason for banging that script together.
Oh yeah and the little atom based Acer netbook, performance was what you’d expect.
Did you check the md5 on the download, you know, just in case?
15 Mar 2020 21:41 #160346 by bevins
No I didnt check it. I will, although, there are alot of threads on the net about ver 19 and slow boots and stuff. Cant find a fix though.
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 23:18 #160363 by BeagleBrainz
I know with the RTAI kernel is a bit slow to get to the login screen, but that is an actual kernel thing, but all you have to do is wiggle the mouse.
Out of interest what is the spec of the machine ? CPU, memory and others.
If you want to post to forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
It may help others and once we get a solution and I'll add it to the first post.
Have you a link to any of the threads. I've never had an issue pop up, the only time I've felt it has been slow is really due to speeds of various usb sticks.
I have a multiboot USB stick that I made myself and it boots all versions fine and that's with using grub to loop mount the iso.
Sounds like a rotten day mate.
Time to create page: 1.054 seconds
