Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
- BeagleBrainz
- Visitor
15 Mar 2020 10:04 - 15 Mar 2020 11:03 #160273
by BeagleBrainz
Qucik and easy kernel & linuxcnc install on Linux Mint 19.x was created by BeagleBrainz
This is for a Mint installation that does not already have a RT_PREEMPT kernel nor Linuxcnc installed.
ie a Virgin installation of Linux Mint 19.x
All kernel packages & linuxcnc packages are downloaded automatically from my google drive.
Download the attached file, open a terminal and in the directory you downloaded to run by
Then follow the prompts and off you go. Tested on Mint 19.2 XCFE, MATE should not be an issue.
mv install-uspace.sh.txt install-uspace.shchmod +x install-uspace.shsudo ./install-uspace.shThen follow the prompts and off you go. Tested on Mint 19.2 XCFE, MATE should not be an issue.
Last edit: 15 Mar 2020 11:03 by BeagleBrainz.
- Thank you received: 7490
15 Mar 2020 10:57 #160276
Replied by tommylight on topic Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Visitor
15 Mar 2020 11:04 - 15 Mar 2020 11:04 #160277
by BeagleBrainz
Replied by BeagleBrainz on topic Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
My excuse is The Toilet Paper Crisis sweeping Australia has affected me
Last edit: 15 Mar 2020 11:04 by BeagleBrainz.
- bevins
- Thank you received: 338
15 Mar 2020 11:13 - 15 Mar 2020 11:18 #160279
by bevins
Replied by bevins on topic Qucik and easy kernel & linuxcnc install on Linux Mint 19.x
Last edit: 15 Mar 2020 11:18 by bevins.
- BeagleBrainz
- Visitor
15 Mar 2020 11:33 #160284
by BeagleBrainz
Oh you missed the the Mint respin with Linuxcnc already setup and ready for installation ?
forum.linuxcnc.org/9-installing-linuxcnc...with-linuxcnc#157411
15 Mar 2020 11:38 #160286
And you missed this
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
But wait, i recall someone...........never mind !
The following user(s) said Thank You: bevins
- bevins
15 Mar 2020 12:37 #160289
by bevins
Yeah I missed that. All that.
I got this down pat with JT's gnipsel page and note I have. It works everytime now, but it is long.
We need a webpage with this. not in the forum unless they sticky it.
15 Mar 2020 12:39 #160291
They are both sticky, under the installation section.We need a webpage with this. not in the forum unless they sticky it.
- bevins
15 Mar 2020 12:44 #160292
by bevins
Yeah, I missed all that. ok no loss. I am going to dig up another hard drive and create one of these dvd's and test it out and see how long it takes.
thanks......
thanks......
- bevins
15 Mar 2020 12:48 #160293
by bevins
Time to create page: 2.666 seconds
