Buildbot repositories down?
31 Mar 2020 22:06 #162304 by andypugh
Replied by andypugh on topic Buildbot repositories down?
Should be back now. It had run out of disk space.
The following user(s) said Thank You: tommylight, oddwick, ikkuh
31 Mar 2020 22:19 - 31 Mar 2020 22:35 #162307 by MarcusM
Replied by MarcusM on topic Buildbot repositories down?
Buildbot repositories are up again
Thx a lot :-)
Last edit: 31 Mar 2020 22:35 by MarcusM.
The following user(s) said Thank You: ikkuh
  • oddwick
  • oddwick's Avatar Topic Author
  • Premium Member
  • Premium Member
01 Apr 2020 02:45 #162326 by oddwick
Replied by oddwick on topic Buildbot repositories down?
hey andy, you ever considered a mirror? what are your bandwidth requirements and monthly/daily load? miiiiiiiiiight be able to help
01 Apr 2020 08:55 #162337 by ikkuh
Replied by ikkuh on topic Buildbot repositories down?
Yes, it works again. Thank you!
01 Apr 2020 08:57 #162339 by andypugh
The Buildbot is nothing to do with me. I think it runs in Seb's garage.
  • oddwick
  • Premium Member
  • Premium Member
01 Apr 2020 16:23 #162356 by oddwick
ahhh, for some reason i was under the impression that you maintained the server.
01 May 2020 11:25 #166306 by Henk
Replied by Henk on topic Buildbot repositories down?
Forgive me for jumping the wrong thread here... but im battling to install master 2.9 using this instructions buildbot.linuxcnc.org/
no errors reported but master or 2.9 doesnt show up in Synaptic after reloading and adding repositories.
i tried:
deb buildbot.linuxcnc.org/ stretch 2.9-rtpreempt
deb-src buildbot.linuxcnc.org/ stretch 2.9-rtpreempt
and
deb buildbot.linuxcnc.org/ stretch master-rtpreempt
deb-src buildbot.linuxcnc.org/ stretch master-rtpreempt
I also tried manually adding them to sources.list, but still no luck
I am starting with a fresh install from the stretch rtpreempt .iso. => 2.7.15
i also ran apt-get update and apt-get upgrade
1st time for my trying to do a major version upgrade, some advice will be appreciated
thanks
Henk
01 May 2020 12:10 #166308 by andypugh
They don't seem to be
buildbot.linuxcnc.org/dists/
It would definitely be master-rtpreempt
Have you added the buildbot signing key as described on the buildbot.linuxcnc.org page?
01 May 2020 13:41 #166313 by Henk
This one?
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
Yes i did. I have followed the buildbot instructions verbatim, or at least i intended to...
01 May 2020 13:50 #166316 by Henk
Did it again, and edited the sources.list to contain only 2.7 and master-rtpreempt
Removed 2.7 in synaptic by using "complete removal" and ran the reload....and it seemed to have worked now,
Synaptic now show 2.9
Time to create page: 0.119 seconds
