Buildbot repositories down?
01 May 2020 14:00 #166318 by Henk
Replied by Henk on topic Buildbot repositories down?
installation successful, sorry to bother you guys with my incompetence!
henk
02 May 2020 09:09 #166395 by ikkuh
Replied by ikkuh on topic Buildbot repositories down?
[quote="Henk" post=166306
i also ran apt-get update and apt-get upgrade
[/quote]
Did you do the apt dist-upgrade?
02 May 2020 15:52 #166413 by Henk
Yes. I did. But I cannot recall in which order. Got it working now. Thanks
17 Nov 2020 13:52 #189592 by Vescovo
Replied by Vescovo on topic Buildbot repositories down?
Hello,
Synaptic Package Manger complains about there is no public key. The key had been put on the keyring already.
In addition the following was issued. The download appeared to work ok.
#/etc/apt/sources.list
# deb cdrom:[Debian GNU/Linux 9.8.0 _Stretch_ - Official i386 xfce-CD Binary-1 20190216-12:51]/ stretch main
deb http://deb.debian.org/debian/ stretch main contrib non-free
deb-src http://deb.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/debian-security/ stretch/updates main
deb-src http://security.debian.org/debian-security/ stretch/updates main
# stretch-updates, previously known as 'volatile'
deb http://deb.debian.org/debian/ stretch-updates main
deb-src http://deb.debian.org/debian/ stretch-updates main
deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
deb-src http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
# Key previously placed on keyring
root@debian-9:~# gpg --keyserver hkp://keys.gnupg.net --recv-keys EF1B07FEE0EE663E
gpg: key EF1B07FEE0EE663E: "LinuxCNC Buildbot <nomail@linuxcnc.org>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
root@debian-9:~#
root@debian-9:~# apt-get update
Get:1 http://security.debian.org/debian-security stretch/updates InRelease [53.0 kB]
Ign:2 http://deb.debian.org/debian stretch InRelease
Hit:3 http://deb.debian.org/debian stretch-updates InRelease
Hit:4 http://deb.debian.org/debian stretch Release
Get:5 http://buildbot.linuxcnc.org stretch InRelease [28.0 kB]
Get:6 http://security.debian.org/debian-security stretch/updates/main Sources [277 kB]
Ign:5 http://buildbot.linuxcnc.org stretch InRelease
Fetched 358 kB in 3s (116 kB/s)
Reading package lists... Done
W: GPG error: http://buildbot.linuxcnc.org stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY EF1B07FEE0EE663E
W: The repository 'http://buildbot.linuxcnc.org stretch InRelease' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@debian-9:~# apt-get dist-upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@debian-9:~# uname -a
Linux debian-9 4.9.0-14-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.240-2 (2020-10-30) i686 GNU/Linux
root@debian-9:~#
  • Moderator
  • Moderator
17 Nov 2020 14:05 #189593 by tommylight
Replied by tommylight on topic Buildbot repositories down?
Works here on 3 PC's.
17 Nov 2020 17:37 - 17 Nov 2020 20:56 #189603 by Vescovo
Thanks tommylight, I will rebuild from scratch.
The installation from CD has some issues. This is the CD
Debian GNU/Linux 9.8.0 "Stretch" - Official i386 xfce-CD Binary-1 20190216-12:51
1) After log-in as userName and setting userName as a member of sudo the instruction sudo was not found.
2) Log-in as root with rootPW if set. I always set it!
su root
rootPW
adduser userName sudo
# Install the sudo executable
apt install sudo
su userName
# Now sudo works but breaks Thunar's ability to view exfat USB drives
# Correct the issue with exfat USB drives
sudo apt-get install exfat-fuse exfat-utils
# Install key for buildbot
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
# Add the following to for the Synaptic Package Manager
echo deb http://buildbot.linux.org/ stretch 2.8-rtpreempt >>/etc/apt/sources.list
echo deb-src http://buildbot.linux.org/ stretch 2.8-rtpreempt >>/etc/apt/sources.list
# You should now be able to download the 2.8 version of LinuxCNC without errors
Very nice work you guys!
Last edit: 17 Nov 2020 20:56 by Vescovo.
  • Moderator
  • Moderator
17 Nov 2020 17:52 #189604 by tommylight
Should not be required, just do and update again.
sudo apt-get update
17 Nov 2020 21:00 #189624 by Vescovo
But sudo was not working so "sudo apt-get update" didn't work? What did I miss?
  • Moderator
  • Moderator
17 Nov 2020 21:47 #189628 by tommylight
OoooK,
If installing Debian, if it asks for a ROOT password = do not enter anything, press next.
Time to create page: 0.415 seconds
