- Thank you received: 9
LinuxCNC on Debian 10 Buster quick and easy install
- Plasmaguy
6 years 5 months ago #167315
by Plasmaguy
Replied by Plasmaguy on topic LinuxCNC on Debian 10 Buster quick and easy install
Im trying this route again and running into an issue. I follow the instructions exactly as they are shown.
plaz@plaz-pc:~$ uname -a
Linux plaz-pc 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2 (2020-04-29) x86_64 GNU/Linux
plaz@plaz-pc:~$ cd downloads
bash: cd: downloads: No such file or directory
plaz@plaz-pc:~$ cd Downloads
plaz@plaz-pc:~/Downloads$ sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
[sudo] password for plaz:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Python bindings for the GtkSourceView widget
GtkSourceView is a text widget that extends the standard GTK+ 2.x text
widget GtkTextView. It improves GtkTextView by implementing syntax
highlighting and other features typical of a source editor.
This package contains the Python bindings for GtkSourceView, and allows
to write Python programs that use the GtkSourceView widget.
Do you want to install the software package? [y/N]:y
/usr/bin/gdebi:113: FutureWarning: Possible nested set at position 1
c = findall("[[(](\S+)/\S+[])]", msg)[0].lower()
(Reading database ... 310448 files and directories currently installed.)
Preparing to unpack python-gtksourceview2_2.10.1-3_amd64.deb ...
Unpacking python-gtksourceview2 (2.10.1-3) over (2.10.1-3) ...
Setting up python-gtksourceview2 (2.10.1-3) ...
plaz@plaz-pc:~/Downloads$ sudo gdebi linuxcnc-uspace_2.9.0~pre0.1456.gdb3a15891_amd64.deb
Failed to open the software package
The package might be corrupted or you are not allowed to open the file. Check the permissions of the file.
- matthewsx
6 years 5 months ago #167327
by matthewsx
Replied by matthewsx on topic LinuxCNC on Debian 10 Buster quick and easy install
I'm getting a 404 not found for the buildbot links
- Plasmaguy
6 years 5 months ago #167330
by Plasmaguy
You should be able to right-click the link and save as.
- Thank you received: 7491
6 years 5 months ago #167342
Replied by tommylight on topic LinuxCNC on Debian 10 Buster quick and easy install
Download that file again, it is corrupted or the download broke.Plasmaguy wrote: Failed to open the software package
6 years 5 months ago #167343
All working now.matthewsx wrote: I'm getting a 404 not found for the buildbot links
- Plasmaguy
6 years 5 months ago #167375
by Plasmaguy
I tried again several times and it fails.
Time to create page: 0.392 seconds
