- Thank you received: 126
LinuxCNC on Debian 10 Buster quick and easy install
- seuchato
Greez
chris
(Installs Buster and a buildbot version of LinuxCNC 2.
This is 99% of what the official 2.8 release will be, so feedback appreciated.
Note that the QTVCP configs need extra dependencies, this will be fixed in the final release.
seuchato wrote: Off curse I had to specify a root passwd, so I had to remove all the sudo references in your script.
It is important _not_ to specify a root password in the Debian installer as this disables sudo for all users.
LinuxCNC relies on setuid, so needs sudo.
This is mentioned briefly in the Buster install notes:
linuxcnc.org/docs/2.8/html/getting-start...th_preempt_rt_kernel
- Thank you received: 7491
I did use the installer from the desktop of the Live version of Buster.
Downloading right now.andypugh wrote: linuxcnc.org/temp/2.8_test4.iso
tommylight wrote: I installed Buster on two computers, never got asked to set a root password, but Wheezy and Stretch did ask for it so i just left it blank and it always worked.
The LinuxCNC ISO will be set up to not ask (it is pre-seeded to blank in the config)
