- Thank you received: 7491
LinuxCNC on Debian 10 Buster quick and easy install
6 years 6 months ago #164445
Replied by tommylight on topic LinuxCNC on Debian 10 Buster quick and easy install
Same here. Getting old is no fun. And i had extremely good vision!BeagleBrainz wrote: Can't see shit without my specs on a computer screen any more.
- bbsr_5a
- Thank you received: 106
6 years 6 months ago #164452
by bbsr_5a
Replied by bbsr_5a on topic LinuxCNC on Debian 10 Buster quick and easy install
thank you
will this be the start of the new standard
as thinking of stretch renewed
or is it the same a sideway to go beside mint
6 years 6 months ago #164458
This is more to prove that getting Linuxcnc is simple and can be done in 20 to 30 minutes flat.
I read everything on this forum and i am getting tired of seeing new users being advised to compile Linuxcnc and kernels to make it work, also building "run in place" Linuxcnc ! Those are for developers and tinkerers and people who have some knowledge of inner workings of Linux and Linuxcnc.
New users want to have a running machine as fast as possible, not spend days compiling.
The following user(s) said Thank You: Mike_Eitel, phillc54, Clive S, CORBETT
6 years 6 months ago #164459
Edited original post to use official Debian Buster kernel.
Makes it even simpler to install.
- strahlensauger
- Thank you received: 66
6 years 6 months ago #164486
by strahlensauger
Replied by strahlensauger on topic LinuxCNC on Debian 10 Buster quick and easy install
That was something I was looking for.
with a
sudo apt-get install grub-customizer
sudo grub-customizer
a graphical tool can be installed to move the extended Options
with the RT Kernel to the top at the bootstart
with a
6 years 6 months ago #164493
If it was needed, i would have posted it. I did remove the pressing ctrl+shift after double checking, in the original post.
No need for that, Debian 10 uses the same kernel as default without RT, so when you install RT it becomes the default.strahlensauger wrote: That was something I was looking for.
with a
Time to create page: 1.346 seconds
