Choosing which Linuxcnc software to install for Ethernet Mesa card
21 Apr 2020 17:44 #164987 by raychar
Hello guys,
I have a new bought Mesa card 7i76e and a Celeron J1800 mini computer. There are two software available: Linuxcnc-stretch-uspace-i386-r13 and Linuxcnc-stretch-uspace-amd64-r13. Which one is suitable for my use? Hope someone give me a guide.
  • Moderator
  • Moderator
21 Apr 2020 18:06 #164990 by tommylight
The other is for older PC's.
22 Apr 2020 10:36 #165070 by raychar
The amd64 one is much larger in size than the i386 one(15.7G vs 1.3G). What effect to the CNC operation if my new computer install the i386 one? (as my SSD is 30G and I want to keep the original Win7 and dual boot with Linuxcnc, in that case only 12G is available), Thanks.
  • Moderator
  • Moderator
22 Apr 2020 11:40 - 22 Apr 2020 11:41 #165075 by tommylight
That can not be right, for sure. They should be very close in size.
Leme check,
All is good, amd64 is 1.2GB, while i386 is 1.3GB.
linuxcnc.org/downloads
Last edit: 22 Apr 2020 11:41 by tommylight. Reason: Link
22 Apr 2020 14:32 #165107 by raychar
my previous download iso file which is large in size don't work(don't know why it is of large in size)... I just downloaded again and is 1.3G in size and it works now..Thanks,
  • Moderator
  • Moderator
22 Apr 2020 20:09 #165154 by tommylight
You can also use this tutorial if you want the latest Debian 10.
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
28 Apr 2020 06:10 #165908 by raychar
For previous installed 2.7 version, it worked. But after updating to 2.8 one, it doesn't, with the error report showed in attachment. How can it be fixed? Thanks,
28 Apr 2020 06:59 #165911 by bbsr_5a
you are refering to a NEWER Computer but took the old J1800 not the newer J1900
going i386 with a 64bit processor is not the best way so go for the MINT if you dont want a big install
  • Moderator
  • Moderator
28 Apr 2020 08:53 #165929 by tommylight
It appears there is the KINS section missing from your ini file ???
28 Apr 2020 10:45 #165951 by raychar
After installing 2.7ver, then went to Repositories and terminal updating as in attached image. What is the mistake?
Time to create page: 1.280 seconds
