Linuxcnc Mint 19.3 ISO
6 years 5 months ago #166569 by Clive S
Replied by Clive S on topic Linuxcnc Mint 19.3 ISO
Hi guys
I was just wondering if anyone has tried updating Linuxcnc on their Mint boxes with the repos mentioned at the start of this thread ?
Everything seems ok at my end, just wanting to know if it works, kinda works or it doesn't.
Rob. I have used the iso on the front page. It loaded for me without issue. :) Thanks.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 5 months ago #166574 by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc Mint 19.3 ISO
Did you install it and attempt to update the Linuxcnc packages ?
6 years 5 months ago #166577 by Clive S
BeagleBrainz wrote: Did you install it and attempt to update the Linuxcnc packages ?
Yes I ran sudo apt-get update sudo apt-get dist-upgrade.
I have just run the above again and it ran fine.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 5 months ago #166593 by BeagleBrainz
Cheers clive much appreciated.
6 years 5 months ago #166607 by tommylight
Replied by tommylight on topic Linuxcnc Mint 19.3 ISO
Last night it worked properly, update and upgrade.
The following user(s) said Thank You: Plasmaguy, BeagleBrainz
6 years 5 months ago #167974 by Clive S
Rob. I might be wrong be I have seen a small problem .
If you try to copy a launcher or a folder to the desktop it can't be seen on the desktop.
But if you then navigate to the desktop with the file explorer, you can see them. Upon exiting the file explorer they appear on the desktop.
I used the iso file 2 days ago then did the update and dist-upgrade. The monitor I am using is 4-3
I wonder if it is putting them of a different workspace ?
Time to create page: 0.171 seconds
