Linuxcnc Mint 19.3 ISO
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 5 months ago #168017 by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc Mint 19.3 ISO
Hmmm I've tried to do it by a number of methods, right clicking and sending to desktop. Copying folder and then pasting onto desktop and copying file and pasting onto desktop folder and can't seem to replicate this issue.
That kind of issue would be a desktop environment issue and should happen with a install done with an original Mint ISO.
6 years 5 months ago #168029 by Clive S
Replied by Clive S on topic Linuxcnc Mint 19.3 ISO
BeagleBrainz wrote: Hmmm I've tried to do it by a number of methods, right clicking and sending to desktop. Copying folder and then pasting onto desktop and copying file and pasting onto desktop folder and can't seem to replicate this issue.
Rob I have switched it on this morning and it all seems fine. I was going to re install and document the steps to try and figure out where it went wrong..
The iso installed very quickly then did the update etc. then I copied a plasmac config fold over and had to run Phill's configurator to get the sim links back which went well. So Mr Murphy might have been at play.
Before it was acting as if the files were hidden on the desktop
Thanks for the sanity check
The following user(s) said Thank You: BeagleBrainz
6 years 5 months ago #168040 by tommylight
Replied by tommylight on topic Linuxcnc Mint 19.3 ISO
Did by any chance the monitor get detached prior to such issues ?
Mint with Mate has a habit of leaving stuff on the desktop or not showing them after messing with the monitors like detaching them and attaching them to the same or another port, same thing on the laptops when switching monitors.
Usually it goes away after a short while, but sometimes only reboot helps.
6 years 5 months ago #168065 by Clive S
No. Its been ok all day today :) Just playing about with setting up a PP with 2 ports for PlasmaC
6 years 5 months ago #168067 by tommylight
Clive S wrote: Just playing about with setting up a PP with 2 ports for PlasmaC
PP as parallel port, or post processor or path pilot ? :)
6 years 5 months ago #168070 by Clive S
Don't take the P out of a pensioner. You wouldn't have 2 ports with a post processor . So yes as a parallel port
Time to create page: 0.403 seconds
