Config Auto-Updater Not Working / Crazy Jitter Numbers?
19 May 2020 17:50 #168288 by tommylight
28 Oct 2020 20:36 - 31 Oct 2020 07:39 #187623 by merkurios
That's strange because I've never had this type of issue and I can't say what might be the reason. Doesn’t it depend on what sort of update policy you have defined? Check /var/log/mintupdate.log, and if that is empty or it does not exist, check syslog for the mint update cron job, something that might prevent it from running. You can also try to run it manually to see what happens: sudo /etc/cron.daily/mintupdate. Anyway, you should keep in mind that we all have those days when all the numbers are wrong and everything just slips out of your hand, so be patient. At www.sunsigns.org/angel-number-55-meaning/ you can find all the meanings of the number 55 from an astrological point of view, and the impact that this number can have on your life.
Last edit: 31 Oct 2020 07:39 by merkurios.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
20 Oct 2021 14:50 #223677 by Youting
Yes Some time we agree with number meaning because It is predicted on basis of astrology and planet science
Time to create page: 2.849 seconds
