What is the recommenced iso to use with the PPort
- Clive S
- Thank you received: 486
19 May 2020 14:57 #168275
by Clive S
What is the recommenced iso to use with the PPort was created by Clive S
What is the recommenced iso to use with the PPort. ?
Would it be this one Mint19.2_RTAI_LinuxCNC2.8.iso by Mr Beagle for older machines
- Thank you received: 7489
19 May 2020 15:58 #168278
Replied by tommylight on topic What is the recommenced iso to use with the PPort
That is not available any more, there is just the Preempt version from Beagle.
Download the stuff from here and install on Linux Mint, should work without to much hassle
www.linuxcnc.org/temp/
Download only linux headers and linux image and Linuxcnc, all 3 only deb packages.
Install by double clicking using gdebi.
Again for older computers, new ones do better with RT-Preempt, some new ones do not do at all !
- Clive S
19 May 2020 16:28 - 19 May 2020 16:39 #168282
by Clive S
Replied by Clive S on topic What is the recommenced iso to use with the PPort
Tom I downloaded the above iso this morning its about 2.27Gb
From here forum.linuxcnc.org/9-installing-linuxcnc...-rtai-and-preempt-rt
Last edit: 19 May 2020 16:39 by Clive S.
19 May 2020 16:58 #168283
Yup mine is still there, but might have issues installing it to HDD.
Please do let me know if it works.
I am very sure that as live version it works properly, as i use it quite often.
- Clive S
19 May 2020 18:36 #168289
by Clive S
Tom I used win32diskimager to write it to a usb. It booted fine as a live disc how would I try to install it to a HD.Yup mine is still there, but might have issues installing it to HDD.
19 May 2020 18:45 #168290
forum.linuxcnc.org/9-installing-linuxcnc...d-rt?start=10#156413
Id does not have the installer at all, so that must be installed on the live session and then an installation to the HDD attempt.
Most probably it will fail to install properly, that is why i suggested the download and installation of the temp files on a fresh installation of Linux Mint.
