Hi All
I have "succesfully" installed the image that Elovalvo mentioned above on a RPI4B-8G unit, but my values are not very good, not to say terrible.
Trying to speed up the boot process, I installed the system on the SD card, and then moved it to a 128GB SSD M.2 disk, running it from there.
Running "top" from command line - I'm barely getting below 2.50 and have seen numbers of 4.60.
Latency tests don't go below 100000ns - But i have seen values above 250000!
That said, latency is not my biggest concern, since I am going to use a 7i76e to control my mill,- but even then - numbers as big as 250000 - would that even work ?
I haven't connected the mesa board yet, since my dell 2418HT touch monitor is also bugging me. It's a very fine monitor, but I have a 1/2 inch black frame all way around the desktop, and I can't auto adjust the monitor, no to talk about thew flickering i sometimes get on the lower 1/4 part of the screen (but that's only when I use the attached mouse - which will be disconnected once touch is fully working).
According to this link -
Dell 2814HT with Raspberry Pi 4
- the 2418HT should be working with RPI4, but maybe it's the LinuxCNC distro that needs tweaking..?
Also still working on getting the touch screen calibrated to actually point where I touch.
My biggest concern at the moment is the performance of the system though.
Aside testing different IsolCPUs settings, what else could i tweak on to get better performance ?
Any input is highly valued!
Thanks in advance
