The limit of 3g of ram isnt that big a deal if your only running linuxcnc, I operate without issue. The 64bit does have lower latency, but I also dont run any ethernet boards.Craig E wrote: Do you think I should go back to 32 Bit OS?
elovalvo wrote: To continue experimenting with using LinuxCNC with a 64-bit kernel on Raspberry Pi 4 I prepared two SD images.
The first, downloadable at the following link:
Linux 5.4.61-rt37-v8 - LinuxCNC 2.8.1
is based on Linux raspberrypi 5.4.61-rt37-v8 with PREEMPT_RT and LinuxCNC 2.8.1
The second, downloadable at the following link:
Linux 5.10.25-rt35-v8 - LinuxCNC 2.9.0~pre0
is based on Linux raspberrypi 5.10.25-rt35-v8 with PREEMPT_RT and LinuxCNC 2.9.0~pre0
Both can be installed with:
Raspberry Pi Imager
that in the latest version (1.6.1) allows you to modify some startup parameters by using hidden commands that can be accessed with the CTRL+SHIFT+X key combination
I checked operation on Raspberry Pi 4 with 2GB and 4GB.
I don't have a Raspberry Pi 4 with 8GB, so it would be interesting to check how it works.
Craig E wrote: Hey All I think I was able to build it on a fresh OS install.
Now I am stuck at the Install phase.
I used elovalvo procedure with Andy's Clone file.
I used the extended wget as elovalvo cautioned me on.
Looks like it is not pointing to the correct location?
This is the error now.
pi@raspberrypi:~ $ wget ftp.it.debian.org/debian/pool/main/p/python-gtksourceview2_2.10.1-3_arm64.deb
--2021-05-06 17:39:46-- ftp.it.debian.org/debian/pool/main/p/pyt...2_2.10.1-3_arm64.deb
Resolving ftp.it.debian.org (ftp.it.debian.org)... 85.94.199.210, 2001:4b78:2000:1::1
Connecting to ftp.it.debian.org (ftp.it.debian.org)|85.94.199.210|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-05-06 17:39:47 ERROR 404: Not Found.
Thanks again for all the support!
