RPI4 Raspbian 64 bit & LinuxCNC
5 years 1 month ago - 5 years 1 month ago #219783 by elovalvo
As mentioned in the first post of this thread,
forum.linuxcnc.org/9-installing-linuxcnc...uxcnc?start=0#178299
you can solve the problem like this:
cd ~/
wget  ftp.it.debian.org/debian/pool/main/p/pyg...2_2.10.1-3_arm64.deb
sudo dpkg -i python-gtksourceview2_2.10.1-3_arm64.deb
sudo apt --fix-broken install
Last edit: 5 years 1 month ago by elovalvo.
5 years 1 month ago #219785 by mwinterm
Thanks a lot! Missed that one... :-)
5 years 1 month ago #219812 by jnp1968
Hi Aaroncnc
Actually that was my bad, didn't look long (or hard) enough for the right info.
I just found this documentation explaining how to do it, and got way better results. Now I'm just worried about the fan not starting, so will set up CPU temperature monitoring and let it run to get a feeling about how it's doing.
Got this case with build in heatsink and fan, just need to be sure that the fan is actually starting up under linuxcnc.
Thanks for your reply :)
5 years 1 month ago #219846 by andypugh
This looks to me like the python-gtksourceview2 module is missing.
For armhf it is available from the LinuxCNC repository
www.linuxcnc.org/dists/buster/base/binary-armhf/
However LinuxCNC doesn't have any files for arm-64.
If we decide to start offering a 64 bit image then that would need to be added. (not difficult)
5 years 1 week ago #223555 by BigJohnT
Just trying this on my Rpi4 and the clone line seems to be off
john@raspberrypi:~ $ git clone github.com/LinuxCNC/linuxcnc.git emc
fatal: repository 'github.com/LinuxCNC/linuxcnc.git' does not exist
JT
5 years 1 week ago #223556 by BigJohnT
One more thing
john@raspberrypi:~/emc $ debian/configure uspace
uspace is accepted for compatibility, but ignored
successfully configured for 'uspace-Debian-10'..
JT
