RPI4 Raspbian 64 bit & LinuxCNC
3 years 2 months ago #279076 by rodw
I Think the password is = cnc
I wish it would create any user as its failing right at the end  when it goes to create a user and does not produce an image :(
3 years 2 months ago - 3 years 2 months ago #279081 by rodw
This image should boot into a Bookworm 64 bit PREEMPT_RT kernel but it does not have linuxcnc on it yet.
drive.google.com/file/d/1H1D6vxyL0cqbkYu..._kp/view?usp=sharing
If any body wants to give it  ago as I won't get a chance until tomorrow
Just burn it using the PI imager as normal and boot.
Any early feedback would be appreciated. Next step is to install linuxcnc from source on this image, record the dependencies etc and build it into the installer.
This video I did shows you how to build linuxcnc if you really want to get carried away (assuming it boots!)
EDIT: Forgot
User = cnc
Password = cnc
No root account
Last edit: 3 years 2 months ago by rodw.
3 years 2 months ago #279167 by Cant do this anymore bye all
Hey Rod does Bookworm work with SPI interface ? From memory last time I tried I couldn't for the life of me get it to work. Ended up using Raspbian based on Bullseye 64 bit.
Been messing around with a Spartan-6 FPGA dev board with modded 7c81 firmware to suit. And some of the Colorlight board based projects.
3 years 2 months ago #279168 by rodw
I have no idea. Andy did some work on the gpios so hopefully it will work now.
He's also writtesn a proper gpio driver but its not in the code yet.
This file is broken so don't download it. There is an obscure issue with the upstream installer which as been fixed so I am updating my repo and hoping to have it building overnight in a couple of minutes
3 years 2 months ago #279209 by rodw
The upstream bugs have been fixed but my download link has not been updated.
Built it again last night with the new framework and it installed fine but it only gave a command line interface.
I installed XFCE and have worked out all the dependencies and linuxcnc is building happily.
Then I will need to script the process in the installer. That might not be easy!
3 years 2 months ago #279236 by thomlop
Yes, thank you. The password "cnc" worked. I'm a total newbie at this so I really appreciate the help.
Time to create page: 0.492 seconds
