Broken packages
17 Aug 2020 18:29 - 17 Aug 2020 18:31 #178499 by shortcircuit48
Broken packages was created by shortcircuit48
Second attempt as first disappeared
I have updated my old Dell i386 with a newer version of Debian however have lost Linuxcnc and have spent countless hours trying to reinstate. I copy line by line and paste to ensure no errors. When I get to "sudo apt install gdebi linux-headers-4.19.0-8-common-rt linux-headers-4.19.0-8-rt linux-image-4.19.0-8-rt-amd64" this results in :
Unable to locate package linux-image-4.19.0-8-rt-amd64
E: Couldn't find any package by glob 'linux-image-4.19.0-8-rt-amd64'
E: Couldn't find any package by regex 'linux-image-4.19.0-8-rt-amd64'
Using Synaptic I cant find this file. What am I doing wrong
I have tried possible incorrectly downloading an alternative but they always come with errors
Any help very much appreciated
Last edit: 17 Aug 2020 18:31 by shortcircuit48.
17 Aug 2020 18:31 #178500 by shortcircuit48
Replied by shortcircuit48 on topic Broken packages
sorry Broken
  • Moderator
  • Moderator
17 Aug 2020 18:32 #178501 by tommylight
17 Aug 2020 19:00 #178509 by shortcircuit48
Thanks for quick reply
I have spent hours on this page following instructions line by line but still end up with missing image.
How can I find the missing image?
17 Aug 2020 19:07 #178510 by shortcircuit48
I have tried Method 2, 2nd line
"E: Unable to locate package linux-image-4.19.0-9-rt-amd64
E: Couldn't find any package by glob 'linux-image-4.19.0-9-rt-amd64'
E: Couldn't find any package by regex 'linux-image-4.19.0-9-rt-amd64'"
  • Moderator
  • Moderator
17 Aug 2020 19:18 #178512 by tommylight
Replied by tommylight on topic Broken packages
It seems you forgot Method2 line 1 :)
sudo apt update
Check if that brings any errors
Then do a
sudo apt-get upgrade
then try line 2.
17 Aug 2020 19:22 #178513 by shortcircuit48
Ign:1 cdrom://[Debian GNU/Linux 10.5.0 _Buster_ - Official i386 NETINST 20200801-13:11] buster InRelease
Err:2 cdrom://[Debian GNU/Linux 10.5.0 _Buster_ - Official i386 NETINST 20200801-13:11] buster Release
Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:3 deb.debian.org/debian buster InRelease
Hit:4 deb.debian.org/debian buster-updates InRelease
Hit:5 security.debian.org/debian-security buster/updates InRelease
Hit:6 buildbot.linuxcnc.org buster InRelease
Reading package lists... Done
E: The repository 'cdrom://[Debian GNU/Linux 10.5.0 _Buster_ - Official i386 NETINST 20200801-13:11] buster Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:5
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:5
W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:5
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:5
apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
python-serial python-yapps
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Looks like there are problems??? How do I overcome?
  • Moderator
  • Moderator
17 Aug 2020 19:32 #178517 by tommylight
You should have led with that, you did not use the linked image to install, but a netinstall instead.
So edit the software sources and remove the cdrom stuff then enable the partner and source code repositories, so after another update it should work.
17 Aug 2020 19:41 #178520 by shortcircuit48
partner and source code repositories Have taken out cdrom stuff but a bit lost with this
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
17 Aug 2020 19:48 #178523 by andypugh
Replied by andypugh on topic Broken packages
You could, alternatively, try the Buster ISO here:
www.linuxcnc.org/temp
It's not 100% ready for general release yet, but it is very close.
Time to create page: 0.130 seconds
