Mint 19.3 Linuxcnc Odroid H2+
6 years 3 weeks ago #184921 by PCW
Replied by PCW on topic Mint 19.3 Linuxcnc Odroid H2+
I would disable:
Intel Virtualization Technology
VT-d
EIST
Turbo Mode
and try again
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 3 weeks ago - 6 years 3 weeks ago #184922 by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.3 Linuxcnc Odroid H2+
Try This:
Chipset -> PCI Express Configuration -> PCI Express Root Port 1 -> ASPM [Disable]
All the other options I left default, Repeated the same for Port 2,3,4,5,6
The above made the biggest change.
Under CPU Configuration I have
Active Processor Cores [enabled]
And all four cores set to enabled
Under CPU Power Management Configuration
EIST [disabled]
Which then disables the Turbo option anyways.
Chipset -> South Cluster Configuration -> HD-Audio Configuration -> HD-Audio Support [disable] HD-Audio DSP [disable] HD-Audio Clock Gating [disable] HD-Audio Power Gating [disable] HD-Audio PME [disable]
Other options were left as default
I've only tested with a NVME module. SATA & eMMC I can't vouch for.
Most recent tests haven't required isolating any CPUs.
Sorry to be a pain Tommy but is it possible to merge this thread with this one forum.linuxcnc.org/9-installing-linuxcnc...3-linuxcnc-odroid-h2 ?
Just so everything is in the one place ?
Last edit: 6 years 3 weeks ago by BeagleBrainz.
6 years 3 weeks ago #184941 by tommylight
BeagleBrainz wrote: Sorry to be a pain Tommy but is it possible to merge this thread with this one forum.linuxcnc.org/9-installing-linuxcnc...3-linuxcnc-odroid-h2 ?
Done.
5 years 11 months ago - 5 years 11 months ago #188135 by thomaseg
Hi, just tested mine today with the recommendations mentioned above. For others who find this via Google, here are what you can expect from this board combined with the image from this thread. Or at least what i ended up with...
Last edit: 5 years 11 months ago by thomaseg.
The following user(s) said Thank You: rodw, BeagleBrainz
5 years 11 months ago #188150 by rodw
Replied by rodw on topic Mint 19.3 Linuxcnc Odroid H2+
Very nice. I have two of them here waiting.....
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
5 years 11 months ago #188152 by BeagleBrainz
Did you encounter any issues that were worth reporting ?
What kind of storage are you using ?
I've only been using a NVME module.
Time to create page: 0.621 seconds
