Mint 19.3 Linuxcnc Odroid H2+
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 1 month ago - 6 years 1 month ago #182144 by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.3 Linuxcnc Odroid H2+
Brand new NVME, I stick with Crucial for SSDs as I’ve always found them to be top notch.
But yeah I’ll look into it.
Well that's strange.
Installed smart mon tools nvme-cli, checked NVME drive, all passes.
Running latency-histogram --nobase with youtube & 5 glx gears min us -33.2 max us 35.5 sdev us 2.5, only has been running for 5 minutes or so.
Last edit: 6 years 1 month ago by BeagleBrainz.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 1 month ago - 6 years 1 month ago #182172 by BeagleBrainz
Well after a couple of hours I ended up with this result. Also had Firefox open with YouTube constantly playing clips. As per normal I disabled the audio harware.
6 years 1 month ago #182191 by rodw
Replied by rodw on topic Mint 19.3 Linuxcnc Odroid H2+
That looks really good Rob. Particularly in the absence of parallel ports and with two network ports, this is perfect for a mesa card.
I don't know if you noticed the Odroid Docs but there are two UARTS on the GPIO connector see:
wiki.odroid.com/odroid-h2/application_note/uart
You can add a RS485 converter. I did find a recommendation to use a MAX3140 if you wanted to use RS485 but can't find a source now
I did notice that the two UARTS come up in Windows as COM1 and COM2
THis would be good for plasma owners or those wanting to use RS485 to control a VFD
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 1 month ago #182201 by BeagleBrainz
And I2c as well.
6 years 4 weeks ago #184546 by htdave
I am trying to install linuxcnc on my new Odroid H2+.
I have downloaded the iso from
cnc.beaglebrainz.net/cdimage/cnc-19.3.0-...lus-uspace-64bit.iso
However, when I try to install, I get the attached error.
Any ideas what is causing it?
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
6 years 4 weeks ago - 6 years 4 weeks ago #184547 by BeagleBrainz
Can you reboot and check this first:
mount | grep efi
lsmod
Then check that you have a network connection.
Last edit: 6 years 4 weeks ago by BeagleBrainz.
Time to create page: 0.266 seconds
