Mint 19.3 Linuxcnc Odroid H2+
- htdave
02 Oct 2020 09:26 #184546
by htdave
Replied by htdave on topic Mint 19.3 Linuxcnc Odroid H2+
I am trying to install linuxcnc on my new Odroid H2+.
I have downloaded the iso from
cnc.beaglebrainz.net/cdimage/cnc-19.3.0-...lus-uspace-64bit.iso
However, when I try to install, I get the attached error.
Any ideas what is causing it?
- BeagleBrainz
- Visitor
02 Oct 2020 10:22 - 02 Oct 2020 10:30 #184547
by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.3 Linuxcnc Odroid H2+
Can you reboot and check this first:Then check that you have a network connection.
mount | grep efi
lsmod
Last edit: 02 Oct 2020 10:30 by BeagleBrainz.
- htdave
02 Oct 2020 10:32 #184549
by htdave
Sorry, I'm new to linux, I'm going to need a bit more explanation.
I didn't have a network connection. Is a network connection required for install?
mount | grep efi
- BeagleBrainz
- Visitor
02 Oct 2020 10:54 #184552
by BeagleBrainz
Yep.
I just booted from the same image and on my end everything is fine.
Once you connect to a network and have an internet connection the install will go ok. Best option is a network cable.
This has nothing to do with me at my end, but is just part of the original Mint installer.
- htdave
02 Oct 2020 10:57 #184553
by htdave
I'll hook up the Ethernet and try again
- wiremonkey
- Thank you received: 4
03 Oct 2020 19:55 - 03 Oct 2020 19:55 #184721
by wiremonkey
Replied by wiremonkey on topic Mint 19.3 Linuxcnc Odroid H2+
Hey, just fired up my Odroid H2+ with 16GB RAM, and your LinuxCNC iso. Running great! Quick question, can I do normal Mint upgrades/updates without fear of breaking things?
For example, it wants me to upgrade to Linux Mint Ulyana 20...
Cheers!
Cheers!
Last edit: 03 Oct 2020 19:55 by wiremonkey.
- BeagleBrainz
- Visitor
03 Oct 2020 21:23 #184731
by BeagleBrainz
Normal updates are ok.
Upgrading is untested and personally I wouldn’t recommend it. You may lose the ability to update Linuxcnc as I have not created a Mint 20 repo.
Do not update/upgrade the kernel. You will lose networking.
Hey mode could we have these last 2 posts moved to the Odroid thread ?
- Thank you received: 6883
03 Oct 2020 22:16 #184745
Replied by tommylight on topic Mint 19.3 Linuxcnc Odroid H2+
Last two posts moved as per request.
- BeagleBrainz
- Visitor
03 Oct 2020 22:47 #184754
by BeagleBrainz
Cheers tommy
- wiremonkey
04 Oct 2020 17:26 #184852
by wiremonkey
Ah OK,
I'll reinstall. Good thing I didn't get too far with my setup. Time to build a controller box... Just digging into din rails and terminal blocks. I've never used them before, but it really seems like the way to go!
Cheers!
Cheers!
Time to create page: 0.211 seconds
