Mint 19.3 Linuxcnc Odroid H2+
  • Moderator
  • Moderator
04 Oct 2020 17:39 #184857 by tommylight
Replied by tommylight on topic Mint 19.3 Linuxcnc Odroid H2+
.. Just digging into din rails and terminal blocks. I've never used them before, but it really seems like the way to go!
I do like them a lot and use them extensively ! :)
The following user(s) said Thank You: wiremonkey
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
04 Oct 2020 21:45 #184877 by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.3 Linuxcnc Odroid H2+
Oh yeah !
05 Oct 2020 01:41 - 05 Oct 2020 02:40 #184905 by wiremonkey
Replied by wiremonkey on topic Mint 19.3 Linuxcnc Odroid H2+
Hey Mr. Brainz, I've got the Odroid H2+ running, 16GB RAM, 256 SSD drive. I don't know how to read these latency tests, but I don't get a sense this is good.
Do you or any one have a list of bios tweaks? Tommy was talking about using AHCI and disabling serial-ata power saving. I'm about to poke around in there, but I really only know enough to be dangerous, as they say.
Here are a few of the settings that I feel might affect performance, but don't really know. I'd hate to recreate the wheel here. If any has tweaked this stuff before, please chime in.
Help me Obe Won Kenobi, you're my only hope.
Here is another latency test after doing a few bios tweaks that seemed to make sense to me. I forgot what I did already. Not very methodical, I know. Oh wait, I remember one of the tweaks, there is a setting in there to tell the bios which OS you're using. The default was Windows, I changed it to linux.
Cheers,
T-
Last edit: 05 Oct 2020 02:40 by wiremonkey.
05 Oct 2020 02:56 #184919 by htdave
Replied by htdave on topic Mint 19.3 Linuxcnc Odroid H2+
BeagleBrainz mentioned isolating cpu 2 and 3 at www.forum.linuxcnc.org/9-installing-linu...3-linuxcnc-odroid-h2
Not sure if that helps
05 Oct 2020 03:04 #184921 by PCW
Replied by PCW on topic Mint 19.3 Linuxcnc Odroid H2+
I would disable:
Intel Virtualization Technology
VT-d
EIST
Turbo Mode
and try again
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
05 Oct 2020 03:07 - 05 Oct 2020 03:17 #184922 by BeagleBrainz
Try This:
Chipset ->
PCI Express Configuration ->
PCI Express Root Port 1 ->
ASPM [Disable]
All the other options I left default, Repeated the same for Port 2,3,4,5,6
The above made the biggest change.
Under CPU Configuration I have
Active Processor Cores [enabled]
And all four cores set to enabled
Under CPU Power Management Configuration
EIST [disabled]
Which then disables the Turbo option anyways.
Chipset ->
South Cluster Configuration ->
HD-Audio Configuration ->
HD-Audio Support [disable]
HD-Audio DSP [disable]
HD-Audio Clock Gating [disable]
HD-Audio Power Gating [disable]
HD-Audio PME [disable]
Other options were left as default
I've only tested with a NVME module. SATA & eMMC I can't vouch for.
Most recent tests haven't required isolating any CPUs.
Sorry to be a pain Tommy but is it possible to merge this thread with this one forum.linuxcnc.org/9-installing-linuxcnc...3-linuxcnc-odroid-h2 ?
Just so everything is in the one place ?
Last edit: 05 Oct 2020 03:17 by BeagleBrainz.
  • Moderator
  • Moderator
05 Oct 2020 07:56 #184941 by tommylight
Done.
02 Nov 2020 19:19 - 02 Nov 2020 19:20 #188135 by thomaseg
Replied by thomaseg on topic Mint 19.3 Linuxcnc Odroid H2+
Hi, just tested mine today with the recommendations mentioned above. For others who find this via Google, here are what you can expect from this board combined with the image from this thread. Or at least what i ended up with...
Last edit: 02 Nov 2020 19:20 by thomaseg.
The following user(s) said Thank You: rodw, BeagleBrainz
02 Nov 2020 20:38 #188150 by rodw
Replied by rodw on topic Mint 19.3 Linuxcnc Odroid H2+
Very nice. I have two of them here waiting.....
  • BeagleBrainz
  • Visitor
  • Visitor
02 Nov 2020 20:53 #188152 by BeagleBrainz
Did you encounter any issues that were worth reporting ?
What kind of storage are you using ?
I've only been using a NVME module.
Time to create page: 0.304 seconds
