Install Debian 10 on ASUS PRO H410M-C
- BigJohnT
- Thank you received: 994
06 Feb 2021 15:46 - 06 Feb 2021 15:54 #197838
by BigJohnT
Install Debian 10 on ASUS PRO H410M-C was created by BigJohnT
I'm trying to install Debian 10 on a ASUS PRO H410M-C with a Seagate ST250DM000-1BD14 SSD. I've tried a bunch of versions of Debian and Ubuntu and after installing at boot up I can see the login prompt for a second then I have to do Ctrl Alt F2 to login to the command line but no desktop at all. Trying a live images does nothing that I can see, just a blank screen.
Running the live Lubuntu 19 from the CD as ugly as it is with the bird on the desktop works!
I've seen people mention something bout SSD being so fast that lightdm fails to load. A stock install and systemctl status lightdm shows it failed. Addingand systemctl status lightdm shows it as active but still no desktop.
I'm a bit stumped and have been beating my head on the desk for a week trying to figure this out.
SSD and MB info
Another tid bit of information the MB will not boot from any of my HDD's that have working OS's on them, the bios can check the smart thing but they do not show up as a boot option...
JT
[LightDM]
logind-check-graphical=trueI'm a bit stumped and have been beating my head on the desk for a week trying to figure this out.
SSD and MB info
sudo dmidecode -t 2
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.2.0 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: PRO H410M-C
Version: Rev 1.xx
Serial Number: 200468358604483
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
sudo lshw -c disk
*-disk
description: ATA Disk
product: ST250DM000-1BD14
vendor: Seagate
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: KC45
serial: 5VY7TV7H
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=f04ed4b5-5861-4b05-945c-8e6ec258f9eb logicalsectorsize=512 sectorsize=4096Another tid bit of information the MB will not boot from any of my HDD's that have working OS's on them, the bios can check the smart thing but they do not show up as a boot option...
JT
Last edit: 06 Feb 2021 15:54 by BigJohnT.
- Thank you received: 7488
06 Feb 2021 16:47 #197846
Replied by tommylight on topic Install Debian 10 on ASUS PRO H410M-C
Enable or disable CMS in BIOS, disable UEFI if possible, and add "nomodeset" to grub.
Sorry, messed up eyes.
- BigJohnT
06 Feb 2021 18:13 #197855
by BigJohnT
Replied by BigJohnT on topic Install Debian 10 on ASUS PRO H410M-C
No CMS or UEFI selections in the BIOS.
grub
In the morning during free time I'm going to download debian standard and install openbox and see if that works.
JT
grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"In the morning during free time I'm going to download debian standard and install openbox and see if that works.
JT
- BigJohnT
16 Feb 2021 16:58 #199085
by BigJohnT
Just booted up from the Linux Mint Mate 20.1 live iso and everything seems to work fine, I guess Debian is broken somewhat.
JT
JT
16 Feb 2021 17:18 - 16 Feb 2021 17:19 #199088
If by any chance you might need QtVCP or the likes or compiling something, use the 19.3, 20 has plenty of issues with Python 2/3.
P.S.
Are you using the free version of Debian or the non-free?
Non-free usually works ok with almost everything.
P.S.
Last edit: 16 Feb 2021 17:19 by tommylight. Reason: more info
- Thank you received: 4150
17 Feb 2021 05:53 #199133
Replied by rodw on topic Install Debian 10 on ASUS PRO H410M-C
It would be interesting to try Tommy's method for quick and easy installs for Debian Bullseye as the PREMPT_RT patch exists for it. It also includes the driver for the 2.5gb network driver used on the Odroid H2+ which would make life a lot easier to use this cool PC.
- BigJohnT
21 Feb 2021 15:54 #199630
by BigJohnT
I tried non-free Debian.
So far Linux Mint 20.1 and 20 will run from the Live iso but fail to install with an error about the CD/
DVD drive being broken but I'm using a USB stick. I guess I'll burn a DVD and see what happens. I've tried both installing the extra stuff and not. The install makes it to the copying files part then fails. Error 5 Input/Output Error
forums.linuxmint.com/viewtopic.php?t=218581
Going to try 19.3 next.
JT
P.S.
JT
21 Feb 2021 20:34 #199646
People have been saying to unplug the USB drive at that error, wait 5 min and reinsert and the install proceeds.
21 Feb 2021 21:16 #199650
Are you trying to create a LinuxCNC/Mint20 ISO?
I did that with 19.3 but it would fail to install correctly, but user BeagleBrains managed to do a proper ISO of 19.3.
Did not try it with 20 or 20.1 as the normal procedure takes about 20 minutes.
I have a feeling removing and inserting USB on Mint has no effect, Mint is much better at finding it's belongings !
- BigJohnT
21 Feb 2021 23:43 #199662
by BigJohnT
Just trying to install an OS right now of any kind that can have a preempt kernel.
JT
JT
Time to create page: 0.631 seconds
