LinuxCNC 2.8.1 configuration doesn't run after upgrading from 2.7.15
5 years 8 months ago #199173 by gaston48
Hello
I have a 2.7.15 configuration with Mesa and concerning a Mikron milling retrofit. It works wellI
I try an update to 2.8.1, but my application does not start ?
A simple step / dir configuration test starts well
My setup has a lot of personal components. They installed correctly, except for a userspace component:
halcompile ignore the singleton statement?
Thank you for your advice
File Name: linuxcnc_report.txt
File Size:14.12 KB
5 years 8 months ago #199176 by chris@cnc
In your debug Information
Error constructing led({'halpin': 'b3ar-led', 'on_color': 'green', 'off_color': 'black', 'size': 10}): Cannot allocate memory
Seems you should update Python or some in this area to
5 years 8 months ago #199183 by gaston48
Thank you for your answer
I didn't do any development in Python.
the error points to a pin in my file
mikron_postguy.hal
I have a trivial configuration
with mikron.xml and mikron_postgui.hal
5 years 8 months ago #199197 by tommylight
Most probably something wrong with constructing the 'pyvcp.b3ar-led' in the xml, dimensions might be off or have a character instead of a number.
The following user(s) said Thank You: gaston48
5 years 8 months ago #199214 by joekline9
2.8 has a bug when it comes to userspace singleton comps.
I had to remove the 'singleton yes' line from the userspace comp file. Then add .0 after each reference to pins etc. in my hal files.
5 years 8 months ago #199225 by gaston48
thank you,
I think my Pyvcp syntax is good, it works fine on 2.7.15.
under 2.8.1, if I modify my config options a little, the error points to other pins
File Name: report.txt
File Size:2.11 KB
Time to create page: 0.200 seconds
