Testing: With the 32-bit kernel:
Feb 20 14:35:46 LinuxCNC-27 kernel: [665942.999739] HAL: creating pin 'set-msg-level.0.level'
Feb 20 14:35:46 LinuxCNC-27 kernel: [665942.999742] smalloc_dn: shmem available 347664
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601371] HAL: initializing component 'mux_generic'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601374] RTAPI: initing module HAL_mux_generic
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601376] RTAPI: module 'HAL_mux_generic' loaded, ID: 5
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601378] smalloc_dn: shmem available 347567
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601380] HAL: component 'mux_generic' initialized, ID = 05
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601382] smalloc_up: shmem available 347552
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601383] smalloc_up: shmem available 347504
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601385] HAL: exporting function 'mux-gen.00'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601386] smalloc_dn: shmem available 347408
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601388] HAL: creating pin 'mux-gen.00.time'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601440] smalloc_dn: shmem available 347312
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601442] HAL: creating parameter 'mux-gen.00.tmax'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601444] smalloc_dn: shmem available 347232
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601445] HAL: creating parameter 'mux-gen.00.tmax-increased'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601447] smalloc_dn: shmem available 347152
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601448] smalloc_up: shmem available 347144
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601450] HAL: creating pin 'mux-gen.00.sel-bit-00'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601451] smalloc_dn: shmem available 347048
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601453] HAL: creating pin 'mux-gen.00.sel-bit-01'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601454] smalloc_dn: shmem available 346952
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601456] HAL: creating pin 'mux-gen.00.sel-int'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601457] smalloc_dn: shmem available 346856
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601459] smalloc_up: shmem available 346832
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601460] HAL: creating pin 'mux-gen.00.in-float-00'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601461] smalloc_dn: shmem available 346736
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601463] HAL: creating pin 'mux-gen.00.in-float-01'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601464] smalloc_dn: shmem available 346640
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601466] HAL: creating pin 'mux-gen.00.in-float-02'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601467] smalloc_dn: shmem available 346544
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601469] HAL: creating pin 'mux-gen.00.in-float-03'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601470] smalloc_dn: shmem available 346448
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601472] HAL: creating pin 'mux-gen.00.suppress-no-input'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601473] smalloc_dn: shmem available 346352
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601475] HAL: creating pin 'mux-gen.00.debounce-us'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601476] smalloc_dn: shmem available 346256
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601478] HAL: creating parameter 'mux-gen.00.elapsed'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601479] smalloc_dn: shmem available 346176
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601480] HAL: creating parameter 'mux-gen.00.selected'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601482] smalloc_dn: shmem available 346096
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601483] HAL: creating pin 'mux-gen.00.out-float'
Feb 20 14:36:14 LinuxCNC-27 kernel: [665971.601485] smalloc_dn: shmem available 346000
With a 64-bit kernel:
[53644.830801] HAL: creating pin 'set-msg-level.0.level'
[53644.830803] smalloc_dn: shmem available 347536
[53658.900348] HAL: initializing component 'mux_generic'
[53658.900351] RTAPI: initing module HAL_mux_generic
[53658.900352] RTAPI: module 'HAL_mux_generic' loaded, ID: 5
[53658.900354] smalloc_dn: shmem available 347423
[53658.900355] HAL: component 'mux_generic' initialized, ID = 05
[53658.900356] smalloc_up: shmem available 347392
[53658.900357] smalloc_up: shmem available 347312
[53658.900358] HAL: exporting function 'mux-gen.00'
[53658.900359] smalloc_dn: shmem available 347200
[53658.900361] HAL: creating pin 'mux-gen.00.time'
[53658.900362] smalloc_dn: shmem available 347104
[53658.900363] HAL: creating parameter 'mux-gen.00.tmax'
[53658.900364] smalloc_dn: shmem available 347024
[53658.900365] HAL: creating parameter 'mux-gen.00.tmax-increased'
[53658.900365] smalloc_dn: shmem available 346944
[53658.900366] smalloc_up: shmem available 346928
[53658.900367] HAL: creating pin 'mux-gen.00.sel-bit-00'
[53658.900368] smalloc_dn: shmem available 346832
[53658.900369] HAL: creating pin 'mux-gen.00.sel-bit-01'
[53658.900370] smalloc_dn: shmem available 346736
[53658.900371] HAL: creating pin 'mux-gen.00.sel-int'
[53658.900372] smalloc_dn: shmem available 346640
[53658.900372] smalloc_up: shmem available 346608
[53658.900373] HAL: creating pin 'mux-gen.00.in-float-00'
[53658.900374] smalloc_dn: shmem available 346512
[53658.900375] HAL: creating pin 'mux-gen.00.in-float-01'
[53658.900376] smalloc_dn: shmem available 346416
[53658.900377] HAL: creating pin 'mux-gen.00.in-float-02'
[53658.900378] smalloc_dn: shmem available 346320
[53658.900379] HAL: creating pin 'mux-gen.00.in-float-03'
[53658.900379] smalloc_dn: shmem available 346224
[53658.900380] HAL: creating pin 'mux-gen.00.suppress-no-input'
[53658.900381] smalloc_dn: shmem available 346128
[53658.900382] HAL: creating pin 'mux-gen.00.debounce-us'
[53658.900383] smalloc_dn: shmem available 346032
[53658.900384] HAL: creating parameter 'mux-gen.00.elapsed'
[53658.900385] smalloc_dn: shmem available 345952
[53658.900386] HAL: creating parameter 'mux-gen.00.selected'
[53658.900386] smalloc_dn: shmem available 345872
[53658.900387] HAL: creating pin 'mux-gen.00.out-float'
[53658.900388] smalloc_dn: shmem available 345776
So, 13 pins on the 32 bit kernel consumes 1664 bytes, and with the 64-bit kernel 1760 (creating float pins)
Creating bit pins the numbers are the same. (which makes some sense as each "pin" is really a memory pointer.
Breaking it down:
32 bits is 256 bytes for the mux function, 168 bytes for the parameters and 1144 bytes for the pins.
64 bits is 336 bytes for the mux function, 176 bytes for the parameters and 1152 bytes for the pins.
It's not a big difference, but there is a difference.
Have you considered just updating the 2.7.15 installation to 2.8.1? There is no need to change the kernel and OD just to run the latest version of LinuxCNC.
