LinuxCNC 2.8.1 configuration doesn't run after upgrading from 2.7.15
5 years 8 months ago #199617 by gaston48
Thank you Andy, i want to try, this would confirm the origin, but I'm afraid
I won't be able to compile and install linuxcnc
I am carrying out the instructions but I do not understand them, I have to go very slowly
If it takes you too long, I can wait with my version 2.7.15
5 years 8 months ago #199759 by andypugh
In a couple of hours you should be able to get a version of LinuxCNC 2.9 (development version) with a HAL memory size of 1MB from the buildbot.
Follow the instructions here:
buildbot.linuxcnc.org
5 years 8 months ago #199784 by andypugh
It looks like it built cleanly. Do you want to give it a go?
The following user(s) said Thank You: gaston48
5 years 8 months ago #199808 by gaston48
andypugh wrote: It looks like it built cleanly. Do you want to give it a go?
Thanks Andy, I'm trying as soon as possible.
By freeing memory 2.8.1 starts fine, but a lot of gpio from my 7i69 are not taken into account. ?
(After a few minutes of switching on, the parasitic cursors of my OLED disappear ??)
5 years 8 months ago #199819 by andypugh
gaston48 wrote: By freeing memory 2.8.1 starts fine, but a lot of gpio from my 7i69 are not taken into account. ?
I was testing with a 7i69 last night, and I have to say that it seemed a bit weird in mode 3. (input states changing to match outputs, without even being wired to anything)
I don't have a 7i73 that isn't buried deep in a machine at the moment to test with.
5 years 8 months ago #199845 by gaston48
2.9.0 is installed, there is no more memory limit now. :)
A lot of my 7i69's gpio are inconsistent. Both are in mode 0. green leds of
watchdog is good. The 7i73 in mode 2
(the parasitic cursors of my OLED is persistent now, but that's a detail)
Time to create page: 0.474 seconds
