VERY new user
  • clive
  • clive's Avatar Topic Author
  • Senior Member
  • Senior Member
11 Mar 2021 21:38 #201870 by clive
Replied by clive on topic VERY new user
I added:
HOME_SEARCH_VELOCITY = 0
HOME_SEQUENCE = -2 # x
HOME_SEQUENCE = 1 # y
HOME_SEQUENCE = 0 # z
to each axis in the ini file. It gave a long error message
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 21:44 #201873 by clive
it doesn't like my # comments on the same line as a command
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 21:45 #201875 by clive
I'm getting a pop-up message about the -2 and the need to home before jogging
  • Moderator
  • Moderator
11 Mar 2021 21:56 #201879 by tommylight
Replied by tommylight on topic VERY new user
And home_search_velocity can not be 0, it will not move the machine at all.
Try 0.5 for inch /or 10 for metric.
Probably that would also need:
home_latch_velocity <<<< at 0.2 /or 5
and
home_final_velocity <<<< at 0.1 /or 1
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 22:04 #201882 by clive
Set velocity to 10mm
The popup says joint 0 is synchronized because of the -2 and requires homing.
Should joint 0 be -2 when joint 3 is also -2 ?
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 22:14 #201887 by clive
I did the dumb and obvious thing and hit the "Home All" button and now X can be manually jogged.:unsure:
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 22:31 #201892 by clive
With a two-stepper gantry system the two steppers are mechanically synchronized at start up so it is a bit odd that they have to be told they are homed. No big deal, I guess.
My next bold step is to haul the computer down the mountain to my barn studio and hook it to the actual machine. I hope the parallel port pin assignments were translated correctly from the Mach configuration. I'll manually check that. I'm pretty sure the Z axis scale will be wrong...
Wish me luck and thanks for your help so far. As the man said, "I'll be back"
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 22:51 #201899 by clive
Next problem. LinuxCNC doesn't like my G-Code !! It says there is no program end, but there is. This is the tail end of my code:
G01 X  +15.424 Y   +2.492 Z-5.000 (Drawn length  965.83mm )
G01 X  +13.829 Y   +2.492 Z-5.000 (Drawn length  967.42mm )
G01 X  +12.234 Y   +2.492 Z-5.000 (Drawn length  969.02mm )
G01 X  +10.640 Y   +2.492 Z-5.000 (Drawn length  970.61mm )
G01 X   +9.045 Y   +2.492 Z-5.000 (Drawn length  972.21mm )
G01 X   +7.450 Y   +2.492 Z-5.000 (Drawn length  973.80mm )
G01 X   +5.856 Y   +2.492 Z-5.000 (Drawn length  975.40mm )
G01 X   +4.261 Y   +2.492 Z-5.000 (Drawn length  976.99mm )
G01 X   +2.816 Y   +2.492 Z-5.000 (Drawn length  978.44mm )
M09 (stop  the pump)
G01 Z +12.000
(travel distance 26.7mm)
(maximum travel distance 248.8mm)
M09 (stop  the pump just to be sure)
G01 Z +30.000
F3000 (move at 3000mm per minute)
(return to the origin)
G01 Y+0.0
G01 X+0.0
M0 (program end)
(Line count 120)
(CNC blocks 4,890)
(Drawing page  size:  250.0mm by  250.0mm)
(Drawing image size:  250.0mm by  250.0mm)
(Kollwitz a CNC Drawing Program)
(Compiled: Feb 27 2021 11:45:12)
(Copyright, Beth Howe and Clive McCarthy,  2021)
(All rights reserved)
11 Mar 2021 22:54 #201900 by Clive S
Replied by Clive S on topic VERY new user
I think you might need an M2 at the end
The following user(s) said Thank You: clive
  • clive
  • Senior Member
  • Senior Member
11 Mar 2021 23:23 #201903 by clive
I have been using M0 for years when I should have been using M02 or M30
Time to create page: 0.106 seconds
