Installing LCNC on Beelink BT3 PRO II
- htdave
Turn off any power saving and you may also use the isolcpu kernel commandline option.
Is there a guide to using isolcpu? I'm a complete newbie to linux
What is an acceptable max jitter for Mesa Ethernet?
Will work through the wifi over the next few weeks as time permits.
Thanks again for all the help
- BeagleBrainz
- Visitor
If you weren’t so north of my location I’d offer my time for nix to help ya out.
- htdave
Maybe I'm better off sending it down to you and getting you to set it all up correctly - I'm happy to pay for your time
- Online
- Thank you received: 7465
126uS for sure is OK (126000 nS), as i have an old laptop that does that and works for days without dropping the link.What is an acceptable max jitter for Mesa Ethernet?
- BeagleBrainz
- Visitor
Don't worry about paying for my time, I've got plenty of that at the moment.
I'll give you my postcode, 2168, just so you can get a quote for postage there and back and we'll go from there.
- htdave
Thanks for that. I've just ordered a usb wifi, so once that turns up, I'll see how everything is going, and if I am still having no luck, I'll ship it down to you.
- BeagleBrainz
- Visitor
tar -cvzf efivars.tar.gz /sys/firmware/efi/efivars/dmesg | grep bcrm > dmesg.txtPlease Log in or Create an account to join the conversation.
- htdave
~$ tar -cvzf efivars.tar.gz /sys/firmware/efi/efivars/
tar: Removing leading `/' from member names
/sys/firmware/efi/efivars/MokListRT-605dab50-e046-4300-abb6-3dd810dd8b23
/sys/firmware/efi/efivars/BootCurrent-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/PlatformLangCodes-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/ErrOutDev-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/BootOptionSupport-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/ConInDev-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/ConOutDev-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/OsIndicationsSupported-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/OA3MSDMvariable-01368881-c4ad-4b1d-b631-d57a8ec8db6b
/sys/firmware/efi/efivars/FPDT_Volatile-01368881-c4ad-4b1d-b631-d57a8ec8db6b
/sys/firmware/efi/efivars/PKDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/KEKDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/dbDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/dbxDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/PlatformInfo-10ba6bbe-a97e-41c3-9a07-607ad9bd60e5
/sys/firmware/efi/efivars/S3SS-4bafc2b4-02dc-4104-b236-d6f1b98d9e84
/sys/firmware/efi/efivars/VendorKeys-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/SecureBoot-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/SetupMode-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/SignatureSupport-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/Boot0006-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/Boot0005-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/BootOrder-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/Boot0000-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/MemoryOverwriteRequestControl-e20939be-32d4-41be-a150-897f85d49829
/sys/firmware/efi/efivars/SetUpdateCountVar-81c76078-bfde-4368-9790-570914c01a65
/sys/firmware/efi/efivars/Timeout-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/PlatformLang-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/dbx-d719b2cb-3d3a-4596-a3bc-dad00e67656f
/sys/firmware/efi/efivars/ErrOut-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/ConOut-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/Boot0004-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/OfflineUniqueIDEKPubCRC-eaec226f-c9a3-477a-a826-ddc716cdc0e3
/sys/firmware/efi/efivars/OfflineUniqueIDEKPub-eaec226f-c9a3-477a-a826-ddc716cdc0e3
/sys/firmware/efi/efivars/OfflineMemoryDumpUseCapability-77fa9abd-0359-4d32-bd60-28f4e78f784b
/sys/firmware/efi/efivars/UnlockIDCopy-eaec226f-c9a3-477a-a826-ddc716cdc0e3
/sys/firmware/efi/efivars/CurrentPolicy-77fa9abd-0359-4d32-bd60-28f4e78f784b
/sys/firmware/efi/efivars/MaximumTableSize-4b3082a3-80c6-4d7e-9cd0-583917265df1
/sys/firmware/efi/efivars/SmbiosScratchBuffer-4b3082a3-80c6-4d7e-9cd0-583917265df1
/sys/firmware/efi/efivars/SmbiosV3EntryPointTable-4b3082a3-80c6-4d7e-9cd0-583917265df1
/sys/firmware/efi/efivars/SmbiosEntryPointTable-4b3082a3-80c6-4d7e-9cd0-583917265df1
/sys/firmware/efi/efivars/TrEEPhysicalPresence-f24643c2-c622-494e-8a0d-4632579c2d5b
/sys/firmware/efi/efivars/Boot0003-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/ConIn-8be4df61-93ca-11d2-aa0d-00e098032b8c
/sys/firmware/efi/efivars/WriteOnceStatus-4b3082a3-80c6-4d7e-9cd0-583917265df1
/sys/firmware/efi/efivars/EfiTime-9d0da369-540b-46f8-85a0-2b5f2c301e15
/sys/firmware/efi/efivars/MemCeil.-01368881-c4ad-4b1d-b631-d57a8ec8db6b
/sys/firmware/efi/efivars/nvram-74b00bd9-805a-4d61-b51f-43268123d113
/sys/firmware/efi/efivars/MonotonicCounter-01368881-c4ad-4b1d-b631-d57a8ec8db6bdmesg | grep bcrm > dmesg.txt Does nothing
I have just plugged in a usb wifi (I believe Realtek) and still nothing
- BeagleBrainz
- Visitor
dmesg | grep bcm > dmesg.txttar -cvzf efivars.tar.gz /sys/firmware/efi/efivars/I meant can you attach the tar.gz (you will need to change to name to efivars.tar.gz ) & txt files as an attachment. So I can download them and do some magic to hopefully get the on board wifi up.
What does dmesg output before & after plugging in the usb device ?
Run this so you have lsusb
sudo apt-get install usbutilslsusbPlease Log in or Create an account to join the conversation.
- htdave
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:f179 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 2575:0401
Bus 001 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 002: ID 0b38:0010 Gear Head 107-Key Keyboard
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubWithout:
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubtxt file appears to be empty
It appears that the realtek is being recognised. apart from that, it is beyond my comprehension
