Installing LCNC on Beelink BT3 PRO II
- Online
- Thank you received: 7465
11 Jun 2021 21:41 #211834
Replied by tommylight on topic Installing LCNC on Beelink BT3 PRO II
It did not.Not too sure if that with survive a reboot.
- htdave
14 Jun 2021 22:13 #212062
by htdave
Replied by htdave on topic Installing LCNC on Beelink BT3 PRO II
Hi Guys,
I'm pretty flat out at the moment, so haven't had a chance to check. will hopefully get there later in the week.
- Thank you received: 4648
16 Jun 2021 12:38 #212197
Replied by andypugh on topic Installing LCNC on Beelink BT3 PRO II
Sorry, late to the thread.
The Beelink BT3 Pro was the machine that I used to test out the LinuxCNC installer ISO when I created it, so the standard installer will definitely work.
But, to get WiFi working I found that I had to uninstall wicd and install nm-tray instead. That got the Wifi working for me, though it is possible that I also installed a brcm file whilst trying to sort it out too. If so I will try to find it.
I keep meaning to make a new ISO, with nm-tray present by default.
08 Jul 2021 07:49 - 08 Jul 2021 07:50 #214010
Having re-mixed the ISO and done a test install, the answer to getting WiFi to work on the Beelink is to ignore the brcm file at install time (I am not sure why, but giving it the file during install does not seem to work)
The answer is here, and can be done after the install is complete.
askubuntu.com/questions/1003350/bcm43455...apter-not-recognised
Last edit: 08 Jul 2021 07:50 by andypugh.
Time to create page: 1.746 seconds
