Installing from linuxcnc-2.8.0-buster.iso fails via USB
4 years 11 months ago #225503 by probotix
Andy,
Can you give a quick tutorial on how to setup and run the live-build system?
4 years 11 months ago #225605 by andypugh
If you download that repository, then you should just need to enter the directory and enter the commands in the readme
github.com/LinuxCNC/buster-live-build
4 years 11 months ago #225606 by andypugh
If you want to customise it, then there is lots of documentation here:
live-team.pages.debian.net/live-manual/h...manual/index.en.html
4 years 11 months ago #225704 by probotix
At the very least, the debian repository URLs have changed. Haven't figured out what else is wrong yet.
4 years 11 months ago #225818 by probotix
Do you have a current set of working commands?
4 years 11 months ago - 4 years 11 months ago #226149 by andypugh
sudo lb config sudo lb build
Seems to work for me.
But I suspect that you need the right things in your apt sources so that it can get all the packages.
deb http://deb.debian.org/debian/ buster non-free contrib main deb-src http://deb.debian.org/debian/ buster non-free contrib main deb http://security.debian.org/debian-security/ buster/updates main deb-src http://security.debian.org/debian-security/ buster/updates main deb http://www.linuxcnc.org/ buster base deb-src http://www.linuxcnc.org/ buster base deb http://www.linuxcnc.org/ buster 2.8-rt
Last edit: 4 years 11 months ago by andypugh.
Time to create page: 0.399 seconds
