- LinuxCNC
- Installing LinuxCNC
- Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
- phillc54
- Thank you received: 2100
08 Aug 2021 11:37 #217211
by phillc54
Replied by phillc54 on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
MX21 should have the same kernels as Debian11, that is the base they build off. I think you are comparing it to MX19.
MX doesn't need an external grub customiser they have one of their own plus a lot of other handy extra tools.
You shouldn't need the headers to build linuxcnc for uspace, only for RTAI.
- robertspark
- Thank you received: 216
08 Aug 2021 11:39 #217212
by robertspark
Replied by robertspark on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
thanks rod and Phil
I'll have a go this evening
- Thank you received: 4145
08 Aug 2021 12:47 #217217
grub-customiizer is now in my synaptic but I don't have the repo set anymore so maybe its now part of the distro Strange....
I have a number of issues on 2 PC's with MXlinux loosing input devices so not keen on it but my primary reason to go to Debian was driver support. There are a few gotchas like adding yourself to the sudoer group but su gives you elevated priveleges.
I have not got the auto logon working. I thought that would be easy. The Screen saver settings are in settings/power settings
Replied by rodw on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
I needed the headers to install some hardware drivers hence they are in the list.MX21 should have the same kernels as Debian11, that is the base they build off. I think you are comparing it to MX19.
You shouldn't need the headers to build linuxcnc for uspace, only for RTAI.When I looke
08 Aug 2021 12:50 #217220
What I've written tonight..Go to the menu and select settings/grub customizerOn the list configuration tab. Click on Debian/GNU/Linux with Linux 5.10.0-8-rt-amd64Click on the up arrow until it's the very first entryCheck on the General Settings tab ensure that default entry is predefined and ther(first entry) is selectedClick on save and close.Restart your machine to boot into the PREEMPT_RT kernelOpen a terminal and type uname -v and check it reports PREMPT_RTAdd your user to the sudoers group by typing usermod -aG sudo your-user-nameIf it does not stick, type su and try againFrom the menu settings/Power manager set the power settings to suit your needs. Now its time to build linuxcnc from source. First we need to install the many dependencies required. Open a terminal window and paste the following in and press enter........Time for a coffee, this will take a while. Now just simply follow the instructions to build Linuxcnc here
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
To create the debs, keep going and the debs will be created in your home directoryOpen a terminal in your home folder or type ~Type gdebi linuxcnc-doc-en_2.9.0~pre0_all.deb Thats it, you are done!
The one thing I could not find was libgnomeprintui-2.2 which is only used by Classic ladder when printing. I've never used CLassic ladder so it was not an issue for me.
The following user(s) said Thank You: robertspark
08 Aug 2021 12:52 #217221
Man this forum editor is really crap. sorry about the formatting/
- phillc54
08 Aug 2021 13:07 #217223
by phillc54
You keep comparing Debian11 to MX19.
MX21 will have the same drivers as Debian11.
08 Aug 2021 13:25 #217225
But I kept getting mouse driver failures on MX (on 2 PCs) and none of the other distros I used did this.
I'm not really seeing any compelling reasons to stray away from Debian anymore as I went to mint to get driver support and compile a PREEMPT_RT kernel in the first place.
Yes, both use the 5.10 kernel but MX Linux did not install my network card on the Odroid and I knew it was in the Debian distro. Maybe MX is pure to open source and does not support the non-free stuff. At least Debian gave me the option to install it.You keep comparing Debian11 to MX19.
- robertspark
08 Aug 2021 13:34 - 08 Aug 2021 13:35 #217227
by robertspark
Man this forum editor is really crap. sorry about the formattformattin
+100
Last edit: 08 Aug 2021 13:35 by robertspark.
- robertspark
08 Aug 2021 13:42 #217228
by robertspark
I installed Debian 11 in a time window I had.... it was missing a driver for my WiFi (fairly newish card.... always worked / loaded fine in Debian 10)
MX-21 was taking way too long ( cement through a straw!)
sort all the rest later
- Thank you received: 7468
08 Aug 2021 19:26 #217257
Replied by tommylight on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
Debian has always two versions of the same release, one free and the other is non-free that comes with plenty of drivers and is much bigger in size.
Use the latter.
Use the latter.
- LinuxCNC
Time to create page: 0.253 seconds
