- LinuxCNC
- Installing LinuxCNC
- Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
- Thank you received: 4149
08 Aug 2021 20:33 #217261
Replied by rodw on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
What is your wifi card (make and model) Is it USB?I installed Debian 11 in a time window I had.... it was missing a driver for my WiFi (fairly newish card.... always worked / loaded fine in Debian 10)
MX-21 was taking way too long ( cement through a straw!)
sort all the rest later
- robertspark
- Thank you received: 216
08 Aug 2021 21:04 - 08 Aug 2021 21:08 #217264
by robertspark
Replied by robertspark on topic Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
wifi all sorted now (its an intel one, needed non-free contrib repository)
try again.... This may be of help to you Rod, it did work for me just fine:sudo geany /etc/lightdm/lightdm.conf
scroll down to about line126 and uncomment (remove #) both of the following lines and add YOUR login user nameautologin-user=rob
autologin-user-timeout=0
Last edit: 08 Aug 2021 21:08 by robertspark.
- robertspark
08 Aug 2021 21:49 #217268
by robertspark
well... progress... make RIP at present.
Linux RobsCNC 5.10.0-8-rt-amd64 #1 SMP PREEMPT_RT Debian 5.10.46-4 (2021-08-03) x86_64 GNU/Linux
dependencies were "interesting".... but sorted now
- robertspark
09 Aug 2021 19:31 - 09 Aug 2021 19:33 #217328
by robertspark
for a RIP build on Debian 11 / MX-Linux 21, what did you do for missing dependancy:
libgl1-mesa-swx11-dev {never mind.... seems to be something of a carry over from Jessie)
Last edit: 09 Aug 2021 19:33 by robertspark.
- robertspark
09 Aug 2021 19:52 #217333
by robertspark
RIP Errors, on MX-Linux 21 (Debian 11)
Opening the QTPlasmaC Sim following build / RIP and Gmoccapy 4 axis Sim
- robertspark
09 Aug 2021 20:01 #217336
by robertspark
python-opengl missing.... for gmoccapy as a dependency
09 Aug 2021 20:02 #217337
From the errors, looks like you missed a few dependencies. Did you open the spoiler in this post hat had them all in it?
forum.linuxcnc.org/38-general-linuxcnc-q...stall?start=0#217208
Just paste it in again, remove any it can't find so it runs. It will ignore anything not required.
09 Aug 2021 20:05 #217339
I think that should be pyton3-opengl but it might resolve to the versionpython-opengl missing.... for gmoccapy as a dependency
09 Aug 2021 20:13 #217340
sudo apt-get install python3-PyQt5.Qsci python-dbus.mainloop.pyqt5
keep them coming I'm updating my list
09 Aug 2021 20:20 #217341
and python3-pyqt5.qtwebengine
- LinuxCNC
Time to create page: 0.259 seconds
