Debian 11/ Bullseye / MX Linux 21 - how to run a buildbot AND RIP install?
12 Nov 2021 12:05 #226216 by bevins
You might know this but I learnt the hard way recently is that when you are in the debian folder you can type ./configure uspace nodocs saves a lot of time... by not building for all the languages you can't read.
And use this to build them
[code]dpkg-buildpackage -b -uc --rfakeroot
Changes to the docs are pending publication...
[/code]
I knew there was an nodocs option like that but really never used it. I will try it and see how much faster it is. I never never use the docs on the machine, I always goto the online docs. But now since the debian stock rt kernel doesnt have support for my wifi dongles I use on machines I guess I might have to turn to using them though for the customer.
12 Nov 2021 20:21 #226244 by rodw
Phil, after building the debs on Debian 11, I get a message from rip-environment script saying its only useful for RIP versions and it refuses to run.. I also thought RIP and debs could exist side by side but they don't for me.
Bevins, stick to using the debs for customers. When doing a RIP build you need to run the rip-environment script before you can use linuxcnc to set all the environment variables to point to linuxcnc. As Phil says, you can work around this to run from a desktop shortcut. But its great for testing and development.
One advantage is you can run multiple RIP instances if you are playing with code. (I have linuxcnc-dev and linuxcnc-pla)
Phil, I think i was confused about doc changes where the commit was pending but not approved.
12 Nov 2021 20:59 - 12 Nov 2021 23:02 #226245 by snowgoer540
The best advice for a customer machine would be to not use MX21, unless I missed the reason for the changeover, it would be better to stay on a Debian 10 based version (MX 19.4, etc.).
As for rip-environment, that’s not true for running base linuxcnc.  It would be true however before running halcompile, pncconf, etc.
running from terminal with this command sets the rip environment by default:
~/linuxcnc-dev/scripts/linuxcnc <path_to_ini_file>
Last edit: 12 Nov 2021 23:02 by snowgoer540.
12 Nov 2021 22:53 #226250 by phillc54
I have just now tried it again here and it works fine but that is probably because of my workflow.
I only build packages occassionaly just to make sure I haven't broken something.
After I build the packages then I run an alias that does a clean/configure/build:
alias lmake='cd /home/phill/linuxcnc-dev/src && make clean && ./autogen.sh && ./configure && make -j$(nproc) && sudo -S make setuid'
Maybe I did that originally because of the issue you mention but I can't remember. :)
13 Nov 2021 03:17 #226271 by rodw
Thanks for the work around Phil.
It would not normally be an issue but You and Greg are so prolific with your updates, 2 a day sometimes, I want some of the features so I am checking the changes and sometimes the commits to see if I need to update. I have never done so many rebuilds :)
13 Nov 2021 03:19 #226272 by phillc54
We like to keep you on your toes. :)
13 Nov 2021 13:23 #226317 by bevins
ok so I compiled the debs and installed master on Debian 11.  So the only way to get updated QTPlasmac is to recompile the debs and reinstall them when there is an update?
[/code]
Whats the syntax? IT says unknown option nodocs
13 Nov 2021 13:35 #226319 by bevins
13 Nov 2021 19:00 #226348 by bevins
WOW, it's fast building with no-docs. Thanks rodw.
Time to create page: 0.123 seconds
