Problem installing on Dell Inspiron 3880
- milu
14 Dec 2021 18:34 #229069
by milu
Problem installing on Dell Inspiron 3880 was created by milu
3880 is a completely generic desktop that I just purchased at Best Buy. When I try to install 2.8.2, I get the following error on boot:This is a bug that was fixed in the current Debian release, but not in Buster or Stretch. As far as I know, that means I can't run any version of the linuxcnc ISOs. But I could build a system from scratch with the iwlwifi fix and add linuxcnc. Unless someone has a better idea, that's my plan. Can someone tell me specifically which kernel is in the 2.8.2 iso? I know it's 4.19, but it helps to have the subversion as well.
Thanks, Joe
iwlwifi .. :BIOS contains WGDS but no WRDSThanks, Joe
- Thank you received: 4150
14 Dec 2021 19:18 #229071
Replied by rodw on topic Problem installing on Dell Inspiron 3880
If you have recent hardware you will require a recent Linux Kernel.
I would probably go with Debian11 non-free (bullseye) and follow the install guide here:
www.qtpyvcp.com/install/bullseye.html
Alternatively, there is a long winded instruction set to install MXLinux on the forum here. They should both give you the same version of the kernel
- milu
14 Dec 2021 20:03 #229073
by milu
Replied by milu on topic Problem installing on Dell Inspiron 3880
Thanks. That would be 2.9 though, right? Is that likely to be stable enough?
- Online
- Thank you received: 7488
14 Dec 2021 22:37 #229082
Replied by tommylight on topic Problem installing on Dell Inspiron 3880
Not aware of any glaring issues in 2.9, but in case you are running a plasma table, 2.9 is a must due to QtPlasmaC.
When installing from scratch, you can always choose the version you want to install, follow
buildbot.linuxcnc.org
14 Dec 2021 23:20 #229083
git checkout 2.8 after cloning the repo to get V 2.8
Sell you could type:Thanks. That would be 2.9 though, right? Is that likely to be stable enough?
- milu
16 Jan 2022 02:49 #231984
by milu
well, 2.9 is a fail. Machine hangs randomly, including but not exclusively when running linuxcnc. Does anyone know when 2.9 will be released? My knowledge of linux seems inadequate to try anything until a supported solution arrives. I guess I could replace the dell, but its hard to imagine that there is something more vanilla out there.
- ALittleOffTheRails
- Visitor
16 Jan 2022 04:31 #231987
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Problem installing on Dell Inspiron 3880
Ok it the machine hangs when not running Linuxcnc it's not a Linuxcnc issue. Remember Linuxcnc is "just a program" running on Linux.
I would suggest to clean the inside of the machine from any dust, pay attention to the PSU and cpu cooler\heatsink\fan. Remove the ram, make sure the ram slots & ram module contacts are clean.
When you say "the machine hangs" does it become totally unresponsive or can you move the mouse, if you press CTR-ALT-F1 does it bring up a text terminal ?
Does CTRL-ALT_DELETE restart the system.
- milu
16 Jan 2022 05:01 #231988
by milu
Hangs as in totally unresponsive to anything except the power cord.
- milu
16 Jan 2022 05:02 #231989
by milu
I should add that linuxcnc is always running (machine is not used for anything else) but it will hang when I'm not using it, or using it.
- Visitor
16 Jan 2022 06:43 #231990
Ok if it is a desktop model I still would recommend giving it a good clean.
Also I would recommend running a memory test.
Not being able to see the syslogs after the crash does make things a little difficult.
How did the machine cope with an extended latency test ?
Also the installed distro and kernel version would be a help as well.
Time to create page: 0.575 seconds
