Installing LinuxCNC 2.8 on Debian 11
- RJ11
4 years 9 months ago - 4 years 9 months ago #232695
by RJ11
Replied by RJ11 on topic Installing LinuxCNC 2.8 on Debian 11
Just to be clear - these are instructions on how to install 2.9, NOT 2.8 as it says in the title
Last edit: 4 years 9 months ago by RJ11.
- BigJohnT
- Thank you received: 994
4 years 9 months ago #232946
by BigJohnT
Replied by BigJohnT on topic Installing LinuxCNC 2.8 on Debian 11
The original question was how to install 2.8 on Debian 11...
JT
JT
- taticelo
4 years 7 months ago #236199
by taticelo
Replied by taticelo on topic Installing LinuxCNC 2.8 on Debian 11
I'm sorry, it wasn't intentional, can you help me?
- RJ11
4 years 7 months ago - 4 years 7 months ago #236229
by RJ11
Hahhaha, I felt the same way I first took a look at this LinuxCNC stuff. Everybody is like screw you RTFM. That's why you won't get any actual answers. Here's the juicy secret that nobody tells you:
1) you CAN'T install linuxcnc 2.8 on Debian 11. Dependencies are broken.
2) You CAN install linuxcnc 2.9 on Debian 11. Unfortunately, v2.9 is bleeding edge and so the only way to install it is to compile it from source code. If you are not used to compiling software from source, it's gonna be EXTREMELY PAINFUL
So, to answer your question, <sarcasm> NO THERE IS NO STEP BY STEP FOR THIS, RTFM!!! Go play in with your toys in the sandbox and just download the ISO image for 2.8 and Debian 10 and install it like this:</sarcasm>
P.S., if you want a sure-fire way to get an actual answer to any forum anywhere, just post something that sounds like you totally know what you are doing but could be completely wrong. If it's wrong, it will be in the very next post. If it's right, you'll hear crickets. Let's see what the next post is in response to number 1) above.....
Last edit: 4 years 7 months ago by RJ11.
- robertspark
- Thank you received: 216
4 years 7 months ago #236266
by robertspark
Replied by robertspark on topic Installing LinuxCNC 2.8 on Debian 11
how do you get that idea?
I must admit I forgot that the question was how to install linux2.8 on Debian 11 (Bullseye).
In short.... you can't. Its not because the dependancies are broken but Debian has moved on from Python2 >> Python 3 so I don't believe that you can install Python2 on debian 11 (bullseye).
wiki.debian.org/Python
Just install 2.8.2 from the ISO if you are new to linuxcnc and it WILL work just fine. If you want to be one the bleeding edge of linuxcnc then yet you will need to compile linuxcnc.... not it's not difficult or complicated.
Here is how to do it.... but yes you do need to RTFM.... or else you won't actually learn how linuxcnc actually works and what it needs to make it work.
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
first open up a terminal
and install git and dpkg-dev
then download linuxcnc from git:
then find out the missing dependancies:
then run:
then change to the linuxcnc-dev directory:
then run the following to find all missing build dependancies and install them:
Once you have installed all the missing dependencies then re-run
in order to check that there are no more missing dependancies. If anything is missing, install it or linuxcnc won't build.
then I would recommend building the debs to install....
linuxcnc.org/docs/devel/html/code/buildi...ding_debian_packages
then run each of the following lines.
once the build is complete then:
there are many links on the forum as to how to install linuxcnc so really you do need to RTFM
sudo apt install -y git dpkg-dev
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
cd ~/dev/linuxcnc-dev/debian
then run:
./configure uspace
cd ..
dpkg-checkbuilddeps
dpkg-checkbuilddeps
cd linuxcnc-dev/debian
./configure no-docs uspace
cd ..
dpkg-buildpackage -j4 -b -uc
cd
ls
sudo dpkg -i linuxcnc_____.deb
- Thank you received: 4153
4 years 7 months ago #236290
Replied by rodw on topic Installing LinuxCNC 2.8 on Debian 11
I have never thought of V 2.9 as bleeding edge. I have used master branch since my very first build becasue it had features I needed.
A shortcut to the installation Robert provided is to use Joco's script to install and build linuxcnc on a bullseye PC
github.com/joco-nz/lcnc-bullseye-installer
The other possibly even quicker way might be to install the brand new deb file on the debian repositories
packages.debian.org/sid/linuxcnc-uspace
Not sure if it will work with bullseye
In a few days it will be in the yet to be released Debian 12 Bookworm (also known as testing). From that point on I won't be bothering with Bullseye/Debian 11 and will go straight to Bookworm
Time to create page: 0.996 seconds
