- Thank you received: 216
Installing LinuxCNC 2.8 on Debian 11
- robertspark
4 years 7 months ago #238429
by robertspark
Replied by robertspark on topic Installing LinuxCNC 2.8 on Debian 11
may want to add a -j switch for your dpkg-buildpackage for your number of processors as it will spreed up the build time
in my case -j4
ymmv
in my case -j4
ymmv
- JYves
3 years 11 months ago - 3 years 11 months ago #257050
by JYves
Replied by JYves on topic Installing LinuxCNC 2.8 on Debian 11
Hi, I'm jean-yves from France,
I compiled LinuxCNC 2.9 and packaged following the RJ11 and robertsparc recommandations.
Added the -j6 since my cpu is a 6 parts amd : it was fast.
But before going futher my questions are now :
1/ Would i have to compile into a realtime kernel?
2/ And may i hope a compiled kernel available and recommended for this ?
Thank's very much in advance.
Here my current kernel:
Linux DebianMsrv64 5.16.0-8.2-liquorix-amd64 #1 ZEN SMP PREEMPT liquorix 5.16-7.1~bullseye (2022-02-09) x86_64 GNU/Linux
SMP PREEMPT but not RT.
For now i just need to drive a CH341 machine (Arduino), it's a common 2D + laser light laser. I'll afford soon a drilling machine.
It is pluged on /dev/ttyUSB0
Thank You.
jeanyves.
Thank You.
jeanyves.
Last edit: 3 years 11 months ago by JYves. Reason: Forget something
- Thank you received: 4153
3 years 11 months ago #257062
Replied by rodw on topic Installing LinuxCNC 2.8 on Debian 11
normally, you would just install the PREEMP_RT kernel with something like
sudo apt-get install linux-image-rt-$(uname -r)
But because you are running a non standard kernel, this won't work. So yes, you need to compile the patched prempt_rt kernel or revert to a debian kernel.
Time to create page: 4.422 seconds
